The red ,green,and blue colors are seperated.screen is blury.and picture is not square.how can i fix this problem without spending money?thanks!!
  • 1 more comment
  • Anonymous Aug 06, 2008
    the red ,green,and blue colors problem,
  • Anonymous Aug 09, 2008
    the red ,green,and blue colors are seperated.screen is blury.and picture is not square.how can i fix this problem without spending money?thanks!!
  • marcipolo321 May 01, 2009
  • 4,234 Answers
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Also, please post the make and model and more specifics can be provided.
Thanks,
Dan
Posted on Jun 19, 2008
I'm having issues with color? Every blue is now green. Can't adjust the tint. Any fixes?
You didn't say what the model number of the TV was, so I'll guess it has tubes for each color Red, Blue and Green. The blue tube is probably weak. If you really want to spend the money on replacing the tubes (costly) you may be able to buy a similar sized flat screen TV for less than the cost of the repairs.
Feb 18, 2016 | Televison & Video
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Green & red tint
Most likely nothing you can do to fix this. CRT TVs use 3 colors to make an image on the screen (Red, Green, and Blue). If you're only seeing red and green then chances are the blue has stopped working. You can replace certain parts in the TV but for a 27" TV you'll probably end up paying more for the repair than a new TV.
I don't recommend taking the cover off and trying to fix TV yourself without training. CRTs have a lot of electricity stored in them (even after turned off) and you could accidentally electrocute yourself.
Apr 06, 2009 | Daewoo DTQ-27S5FC 27" TV
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Color in TV
I have the same problem. I had a tech guy come to the house and there is a part that needs to be ordered for it. If you have a warranty it is free but if not the tech guy said the part costs from $450 to $500.
May 09, 2008 | Vizio L32 32 in. LCD HDTV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
