My DTV-3100HDD only gives B/W outputfrom the second Scart socket. What can I do to correct this ? The cables are ok.
  • 3 more comments
  • gerald874 Jun 20, 2008
    When I plug the PVR into the TV, I get a colour picture, but if I move the Scart plug to the second - video - output I get a B/W picture/ If I plug a DVD recorder into the video output socket. it will only record in B/W. HELP!!!!
    I have used two different cables after visual and continuity checks and changing over end to end with both cables, and get exactly the same result ie. colour from the TV output of the PVR and B/W from the video output socket. What now?
    The last check was only between the PVR and the TV, and I checked that the PVR was correctly set on Pal.
    My TV is an older CRT type and only has PAL and I have double-checked that the PVR is set on PAL. The only answer seems to be that the video output of the PVR is at fault.
    Many thanks to the guy who helped me. Am only sorry that we couldn't resolve this problem.
    Sergeant:
    Champion:
  • 304 Answers
Well the tv may have the problem on the video output, or the device you connect was not comptible with the tv system that you have..
Posted on Jun 20, 2008
    Master:
  • 638 Answers
The best solution i can give you is try interchanging your DTV-3100HDD in another TV with same wires what you are using with this TV.if not possible check with another DTV-3100HDD in your TV with same wires. if both the options are not possible for you to do get your DTV-3100HDD to any TV reparing shop and just tell them to check your unit on their telivision.but tell them to check with your same wires which you are at present using. once you get the option where the problem is you yourself can follow the further steps to be taken.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 4,472 Answers
This sounds like a common problem with these players that Marantz usually can't solve themselves. I would contact Marantz directly and see what they can do for you. http://www.marantz.com/
Thanks,
Lee
    President:
  • 2,712 Answers
Most likely an issue the SCART connector or the circuitry..unfortunately, it is difficult to diagnose like this..best get it by a TV repairman, who will be able to diagnose it for you..
  • 2,071 Answers
The problem of yours is in the system setting,for compatibality of the unit like AUTO to AUTO ; PAL to PAL ;NTSC to NTSC,,maybe you cannot get it right, just go to menu system then choose the system , If you cannot got the right system the result is black and white ;you better checked it out....
  • 1,512 Answers
It may be that you have to go to the menus for each input and select the correct system for the signal you are feeding in. pal ntsc, and so on.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
    Master:
  • 848 Answers
Just check whether the plugs are working properly...
    Sergeant:
    Champion:
  • 230 Answers
Try by hard reset method , that is, unplug all the cables wait for half an hour and replug all the cables and try
Posted on Jun 19, 2008
Papajomz
If your TV is not in Digital it won't give you the tuning option.
Select DTV from ythe on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
Mar 30, 2011 | Computers & Internet
I have an old magnavox tv and am trying to hook up a magnavox dvd player but there are no hookups in the back. It is a model #RR254oA 102, Ser# 13610889 purchased in 1992. Can you help me? Sincerely,...
are there any places for av cable to be plugged in? We have an older tv that only plugs in the front. I have a 20" magnavox tv too, about a 1993-94 model And it has the colored (red, yello, white) av plug ins in the back. Yours doesnt have this? Please reply.
Sep 03, 2008 | Televison & Video
When I switch on my dvd even the set up page is in black and white. Originally I was getting no picture so I made sure everything was plugged in. Then I got the black and white.
Check the scart cable , try connecting it to another scart socket on the tv. I would even change the scart lead to make sure its ok. I have had loads of similar problems like that caused by scart leads faulty or connected to the wrong socket.
pete.
Nov 27, 2010 | Philips DVDR3380/05 DVD Recorder
Sound but no picture
ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
Feb 06, 2010 | Televison & Video
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
Nov 29, 2009 | Panasonic CT-32SL14 32" TV
I have put a scart lead from the av1 socket on the dvd (panasonic) to the cable box vcr connector on the back of the cable v+box and run a hdmi cale from the hdmi socket on the dvd to the hdmi2 socket on...
Ok, first thing first if you have a cable box and a dvd player both been connected with HDMI cables direclly to the TV you just need to run a cable from the TV were it says audio out into your receiver.
This way everytime you change from Cable box and DVD the audio automaticly will change as well.
Jul 15, 2009 | Electronics - Others
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Wiring diagram for sony kdl-23s2010
i can tell you the best way but i need to know what your using ie scart leads things like that also tell me how many scart sockets in telly and in dvd and sky and vcr after you give me this info il tell you what needs pluggging into what
basing it on your telly has 2 scart if not let me know ok
1. dvd to telly via scart lead
2. then sky to vcr via scart doing it this way allows you to record sky using av channel on vcr
3. vcr to telly via scart lead
then if you want your video to record normal telly channels you need to use normal arial leads in this order
1. from arial to vcr then from vcr to telly doin this allows you to record the channels you get through the arial like 1 2 3 4 5 also this way when you choose 1 or 2 or 3 on video it will record that channel allowing you to watch whatever on sky whilst recording normal telly
If your telly only has one scart socket in the back then you need to buy a scart adaptor that converts one scart socket into 2 or even
let me know if you understand what im telling you or if you need further help ok just let me know im going out for 2 hours but will check your reply then so hope you dont mind waiting if you need help ok
Feb 18, 2008 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
