Question about GE Spacemaker JVM1640SJ Microwave Oven
Fan will not stop
The fan will not stop running on our GE JVM1870BF06 Microwave
oven. Everything else works properly.
  • fodav Jun 20, 2008
    The vent/exhaust fan in the grille across the top. Thanks
  • William Miller
    William Miller May 11, 2010
    Do you mean the vent / exhaust fan in the grille across the top or the cooling fan inside behind the control panel?
  • GE Master
  • 9,098 Answers
That is probably a shorted vent motor triac on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 20, 2008
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
Vent fan has stopped working. the keypad says vent fan off. when pressing help, it says press this pad. nothing happens.
A low tech solution worked for me.
I too was getting the "Vent Fan Off" message, and despite the fact that everything else worked fine with the microwave, I turned the breaker off and back on from my electrical panel. The fan works fine now.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Check this one out! My GE Profile microwave heats up but I don't hear the fan. However, the inside light and the turntable stopped working at the same time. Everything else seems to be working fine. What's...
hello,
this is a maize problem that wiring (wire) this means that your oven fan has been disconnected from it position
what you need to fix up your fan back is that you unscrew your oven trace the maize that supply A/C to the microwave
this maize is connected to different object but what by you are real after is your fan and the heater including the turntable .
trace the wire down to the fan to locate the loss wire from it position and do the fixing your self because it is same maize thaat link up both together i.e fan and turning table
please note before you can do this make sure that any form of power supply is put off.
Good luck and thank for using fixya.
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE jvm1790 microwave that when its pluged in, the magnatron fan runs with the interior light is on constantly. I can't start either the microwave or convection. Everything stops when the door is...
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Nov 06, 2009 | GE JVM1790SK Convection/Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sometimes the microwave shuts off (and will not restart) during a cycle--as if it internally overheats. After a period of time, it will again operate properly
It is overheating, but what I need to know does the fan work when microwave is running and at some point the fan cuts off even with the microwave still running? if so it may be that the fan is kicking out and then microwave runs and gets hot.
Aug 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
87 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
