Question about Asrock 775VM800 Motherboard
Asrock motherboard hello i have got a new motherboard and,i pulled the wires out from the power button and reset, the speaker wires are no problem, as they are made to marry up along with the fan conecters but the other wires i have not got a clue, could i get a wiring diagram from you please maybe this will helpon the board it as got [pled underneth it as got hdled] at the side[ pwrbin under neath it as got reset] 8 pins hope you can help ?
  • jimbow1 Jun 20, 2008
    hello may i say a big thank you to all concerned just one more question? how do i put this document onto my computer,incase i have to refer to it again, once again a very big thank you.
  • 818 Answers
  • Sergio Scalfaro
    Sergio Scalfaro Jun 20, 2008
    i'm very happy that this resolve your matter !!!!!!!!!!!!!
  • Sergio Scalfaro
    go to download page and download it
Can you please show how to re-connect power led, power switch reset switch, hdd led &speaker cables to asrock k7vt4a+ motherboard diagram would be appreciated
there must be writen somwhere in the board it self. can you see the panel where you are trying to fit? see the whole board and you see the settings of it. just read what is written downwards to the first pci slots. i think this the setting.
Apr 16, 2011 | Asrock K7VT4A+ Motherboard
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
HOW TO CONNECT AHDD LED IN ASROCK MOTHER BOARD
Just parallel to Power LED button you find HDD or IDE LED button, the red coloured wire should be top and the white coloured towards reset connection.
Sep 11, 2010 | Zerus Intel Desktop Board D815EEA...
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
Swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Nov 02, 2008 | Asrock 775VM800 Motherboard
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
No place to plug in case power/reset button plugs on k7vm3 motherboard... And some other case wires too =(
here is the link for user manual for your motherboard
you will find the answer for reset button in page 17
but no place unfortunantly for you case power
http://www.asrock.com/manual/K7VM3.pdf
AYADI
Apr 07, 2008 | Asrock K7S8XE+ SIS748 (K7S8XE+RAID)...
Asrock 775VM800 Motherboard Logo
126 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
