Question about Disney 13" TV
TV Remote Hello, Is there a way to change the INPUT selection without the need of the remote, fromt he TV Menu. Unfortunately the input option on the remote doesn't work. Please advise.
  • Anonymous Jul 16, 2008
    how do you switch from TV to video so you can play a dvd
  • 417 Answers
I posted a fix on one other thread, you can get a universal remote to acces that function, newer directv remotes have the menu function
J
Posted on Jul 11, 2008
When pressing menu on remote control I do not have a tv section listed to tune in channels
The TV channel settings Menu is usually only available when the Input is on TV. Look for a Source or Input button on the TV or the remote. Press this button and try to change to the TV source option.
Please add a comment with the make and model of the TV for additional information. (Unfortunately, many TVs don't let you change the source after pressing the Menu button and they don't always have a Source/Input button on the TV. Additionally, some replacement remotes don't even include a Source or Input button. For those with an Input button, you may need to try other codes to see if any will correctly work with the TV.)
Nov 05, 2015 | Televison & Video
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
Insignia ns27rtv can not change input without remote
As there is no menu button on the front of the TV, you must have its remote control to select he inputs.
Jan 11, 2013 | Insignia Used Original NS27RTV Remote...
How do I tune my sylvania tv model SRT2127S to video mode with out a remote
If there is Menu button on the front panel to your tV, you can get ito its menu, and can select inputs, by entering into int input selection option. If there is no Menu button, there is no other way to select the input, without a remote control
Mar 08, 2012 | Sylvania Televison & Video
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
No remote need to put on input for game system
One option is to get a new remote. http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=ST420ff&uuid=12852168657330 will order the original remote. Any universal remote with an Input function should work (assuming the remote is newer than the TV by at least 6 months).
I wish I could be of more help.
(Unfortunately this is a tv that doesn't let you change the input from the OSD menu.)
Sep 23, 2010 | Symphonic ST420FF 20" TV
Emerson TV input option
Tries the channels + or - buttons a couples times on the tv manual controls buttons on the tv.U will get in the input option.This solution work for many tvs don't the input option on their universal remotes,without the original remotes.Ur tv don't know.
Jun 02, 2010 | Emerson EWF2704 TV
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Disney 13" TV Logo
345 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
