Question about Whirlpool Dryers
Whirlpool gas dryer model # LGR4634JQ1. The dryer has an initial flame when first started up, but after about 15 seconds the flame goes out and the dryer remains cool.
The flame sensor is probably bad. This is located on the side of the tube the flame is in. Has two wires going to it. Try to short it out and see if the flame stays lit. UNDER NO CIRCUMSTANCES OPERATE THIS DRYER WITH CLOTHES IN IT WITHOUT THE FLAME SENSOR IN PLACE!!!!! The other problem might be air flow. If the duct is blocked the flame will trigger the high limit switch. Take the hose off the back of the dryer and turn it on. There should be a lot of air flow. If there is and the flame stays on the duct hose or outlet is clogged.
Posted on Jun 29, 2008
Model LG8219W2 On initial start up igniter turns on and flame is ok, after heats up and cycles the flame does not reignite,I can see the igniter glow red but flame does not return. the igniter contiues...
HI. This will essentially be an issue that concerns the gas valve coils. With that said, I will post below a complete burner assembly procedure that will help you isolate the culprit. I'm sure that the coils will fail the test, but to be safe, follow the procedure to confirm.
Gas valve/Burner testing procedure:
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Click Here to access a exploded diagram of the burner assembly. The affected coils will be labeled number 15 and 10. The actual coil and valve assembly will be labeled number 11 and the burner will be labeled number 9
Aug 22, 2010 | Amana NED7200TW Electric Dryer
The flame goes out after 15 seconds, then 1 minute later comes on for 6 seconds. Replaced the coils and the problem continues. Replace the flame sensor?
Pull the 2 wires going to each thermostat and tape them together until you find the defective t-stat...I beleive you have 2 of them plus 1 white one in the rear of the dryer..
Oct 20, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer starts then flame goes out in about 15
Check that the lint filter is clean and that the exhaust vent is not clogged. Make sure it is clear all the way to the outlet. If no vent obstruction then the gas valve coils probably need to be replaced.
Sep 21, 2009 | Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Whirlpool LGR4634JQ1 Ignites the first time, then will not ignite
Hi, You will need to change the coils on the top of the gas valve. They are a plug in coil. This is a very common problem. If you need assistance on how to change them or the part#, I can help you. I would need you model#.
Thanks
Vic
May 13, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Wirlpool gas drier flame comes on for the initial start then goes out and wont come back on to finish drying clothes?
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
http://www.applianceaid.com/gas_dryer.html
I had a problem much the same as you and replaced the coils. Works like a charm now.
Mar 31, 2009 | Whirlpool LGR7646E Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Check for a restricted vent. Clean vent and check for kinks. Make sure lint screen is clean. If you do-not have good airflow due to a restriction, the burner will not stay on. It's a safety thing.
Nov 18, 2007 | Whirlpool LER5636P Electric Dryer
Open Questions:
Dryers Logo
240 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
