Question about Apple 20" Flat-Panel TFT LCD Cinema Display
Apple 20" monitor
My new Apple 20" monitor keeps turning itself off and on while in use.  The screen goes black, then comes on again.
The cables are all installed correctly.
I noticed the LED flashed 3 times recently (short short short) and so reset the PRAM according to the instructions on the Apple website.  But no, the problem persists.
I also attached a surge protector, but that doesn't help either.
  • jeangail Nov 09, 2008
    My son and I each have an Apple 20" Flat-Panel TFT-LCD Cinema Display monitor. I experienced the the problem of a bleck screen first. When checking the net for a solutions it was suggested I purchase another power brick which I did from an online source about a year ago. Switching the power cube when the monitor blacked out worked so I ended up alternating the power cubes frequently. Recently my son's monitor started acting up the same way. We ended up alternating our three power cubes. It seemed that resting the cube a bit seemed to work. Now we have the problem that none of the three cubes are working for us leaving us with two useless monitors.
  • Apple Master
  • 1,830 Answers
How old is your monitor?
Posted on Jul 01, 2017
4 Suggested Answers
  • 35 Answers
SOURCE: Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Posted on Oct 27, 2009
SOURCE: Apple Cinema display goes BLACK after start-up
My G4 has a ADC & VGA on the same card. The VGA works but the ADC, is doing the same thing as you described. I am searching the web, and can not find an answer to this problem. George 3/21/2010
Posted on Mar 21, 2010
My ipod touch wont turn on, it shows the little pple symbol on the screen, then flashes white, blacks out, and the apple appears again. I've pressed all the buttons to try to get it to work, but it keeps...
try holding the menu button and the power button for about 20 secs. this will cause it reset, if this method doesn't work, then hold down the menu button, connect it to a PC then hold down the power button, if you have Itunes installed on your computer, it will alert you that it detects an Ipod in recovery mode, basically after that it'll attempt to fix your problem, and it will be able to turn on again.
Jan 18, 2010 | Apple iPod touch
Screen turns on 1 second then turns black
With a known working monitor try it on the computer. If the monitor stays on then you know the original monitor is bad. If the monitor goes off after 1 second again, then you know that the video card is bad.
Aug 19, 2009 | Samsung Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
Mar 08, 2009 | Computers & Internet
bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Feb 01, 2009 | Star Logic 17" LCD Monitor
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Apple 20" Flat-Panel TFT LCD Cinema Display Logo
105 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
