1998 Mercury Sable Logo
Posted on Jun 19, 2008
Engine Racing I was stopped in traffic and the car wanted to go forward with my feet on the brake. I had a hard time steering the car to keep from hitting the car in front of me with my grandkids in the car. (the motor in the car did start racing and the car was trying to go forward with my feet on the brake. )What should I do? This is very dangerous.Frank Taylor
  • Anonymous May 11, 2010
    Good job at controlling the situation!
    Now, lets fix this thing.
    Does it do it all the time, example, if it's in park?
A
Anonymous
It's the IAC valve, take it out and cleane inside. the spring and valve area.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jun 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2480
Points
It may be the cruise control cable - I had a vehicle do this to me before. The engine raced as soon as I started it, even in park. A couple of times, it stopped racing - then I pressed the gas pedal, and the RPMs did not drop when I released the pedal.
If it acts somewhat like that, check under the hood and find the cruise control system - it is most likely a 3-4" diameter, 5-6" long cylinder-like object mounted on top of the engine with a long cable coming out of it going toward the back of the engine. Check all of the clips on the cable and make sure they are intact, then make sure the cable is fully attached to the throttle body at the end. My cable came loose and got itself wedged in the throttle body, preventing the throttle from closing.
If the cable seems fine, check for other obstructions on the throttle body - there may be something else holding it. It may help to have somebody inside the car pressing and releasing the gas pedal (engine off), so you can see whether it fully opens and closes.
2answers
Why does my 2005 chevy colorado steer so hard I can't turn the wheel unless I'm moving forward also when applying the brake when coming to a stop my engine wants to cut out rpm dropping below 500 help
You may have more than one problem. Start with the power steering. If the power steering pump is causing a problem it may be seizing causing hard steering at slower speeds and putting an extra load on the engine causing the lower RPM's. Have this checked first.
Steering wheel vibrates when Im stopped at a light
You may have front brake rotors which are slightly warped. The ABS only comes into play under very hard brakeing conditions. Typically you may also feel a slight pulse in the brake pedal as you slow down.That would be my best guess.If you have a vibration when you are stopped, that may be a motor mount issue. Either the front and/or rear mount may be weak.They are designed to isolate small engine vibrations you might feel when the car is at a stand still The motor mounts are designed to isolate small engine vibrations at a stand still at idle as well as limit the amount of travel the engine can make under a load. As a car gets older, the rubber which is what the mounts are made of get harder and often collapse slightly and can cause your condition because they are no longer plyable.Maybe this might shed some light on your problem. Good luck.
3answers
Does 4 wheel drive help you stop faster or is it just a traction device
Four wheel drive is a traction devise. Not a braking devise.
So, no it will not help you stop faster.
That said, on slippery conditions when you let off the gas the extra, "traction" will help slow you down if you do not slide.
Hope this helps you out.
Wayne
When u start it it idles high and when u are stopped at a light or in traffic u have to hold brake 2x as hard as normal cuz the high idle makes it want to keep on going. it does not ever stop idiling...
You do not state year or model. Many Chevrolets have electric idle control, and it could be out of adjustment. Also, a loose vacuum line could increase the idle by a significant amount. At 2000 rpm, when stopped, the engine really wants to drag the car forward, hence the extra effort to keep it stopped. Furthermore, dragging the vehicle forward continuosly will eventually damage the automatic transmission torque converter.
1helpful
1helpful
2answers
Engine suddenly revs when stopped & @ idling
sounds like one of the metal arms connected to the engine may be getting stuck some how. have someone get in car and press on gas when car is off while you watch engine to see what is moving, then check those arms to see if there is any possible obstructions or knicks or something on them
Clutch problem
Its is totally acceptable to reuse a flywheel as long as it was machined to where a new finish was achieved.A machine shop will cut off about .020"-.050" to achieve a new,machined finsih.Same concept as turning brake rotors when performing a brake job.Have the clutch hydraulics checked,as this is what applies and releases the clutch when actuating the pedal.The clutch pedal engagement point is also adjustable up under the dash.One thing to remember when driving a manual trans vehicle is,for example,when sitting at a stop light.apply the brake and sit still.I can't tell you how many times i've seen people sit at a stop light,and rock the vehicle back and forth by applying then relasing the clutch pedal,causing the vehicle to pull forward a couple feet,then roll back a couple feet,pull forward,and roll back.This severely shortens the lifespan of the clutch,as it gets TOO hot.If at a traffic light,just apply the brake and sit still.There are correct and incorrect ways to drive a manual trans vehicle,all of which is determinate of how long the clutch will last.
1helpful
My brake pedal is hard to push in. the car wont/ is hard to stop. i replace the brake pads and the calipers. what could be the problem now?
i guess your brake booster is the problem. try this.... engine not running just pump the brake at least 25 times at the 25 count,just keep your feet on the brake pedal and start the engine. if the brake pedal won't go down even a little... your brake booster is gone. or something with the vacuum.
3answers
Brake problem
master cylinder is failing or not enough fluid in the resevoir <<< (spell check) animal chewed threw brake line faulty hardware on brake failing
take into nearest brake tech for inspection
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
