Question about Kitchen Ranges
Electric stove power will not stay on after turning off knobs
  • 868 Answers
Normal conditions are as follows power on when knob turns it on ,and, knob turns to "off" ,power is off. What is it I'm missing here?
Posted on Jun 19, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 19, 2008
    "power will not stay on after turning off knobs"
    THIS IS WHAT YOU POSTED, AND I FEEL YOUR RATE OF "INAPPROPRIATE" IS UNJUST.
On my electric stove, one of the burner caught on fire, and now the indicator light stays on even after the stove is turned off
If the light remains on, that would indicate the circuit was damaged. The light goes on when the circuit is complete. This usually happens when the burner gets hot. If it caught fire, then the stove is registering it as hot all the time.
Elisa Jed ' http://www.atlasappliances.com/en/pg-kitchen-appliances
Jul 07, 2014 | General Electric Stove/Oven/Range Chrome...
Tappan gas stove
Older gas stoves used a battery to ignite the flame but due to its age, I would get a hand held gas lighter.
Apr 21, 2017 | Kitchen Ranges
Nobs on stove won't go off
For starters turn the electric off. Is your range gas or electric? When you turn the knobs to off do the lights stay on? What brand and model number do you have?
Jul 30, 2013 | Cooktops
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Kenmore stove surface unit light stays on
YOU HAVE A SURFACE UNIT SWITCH GOING BAD take off the back and look at the switches if you have a volt ohm meter you can check for power to the light if you dont have a meter you can unplug the stove and pull each wire 1 at a time and see which one is sending power when plugged back in once you find the one replace it and problem solved
Jan 09, 2009 | Equipex PZ-330 Electric Single Oven
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
