Question about iRiver H320 MP3 Player
Iriver h300 drive problem
Whenever my iriver h300 is turned on, i get this message 'check hdd connection' while the device is booting. although i had over 2000 songs and 400 folders, the device now shows 0000 (zeros) for both songs and folders. i guess they cant be accessed anymore. how do i get around this problem.
I may be wrong but mine does this too, and I'm pretty sure it means that the hard drive has been damaged. It is not able to read the information stored on it. I think you can buy a replacement hardrive though and try to repair it yourself, though they are becoming harder to find these dayz
Posted on Jul 15, 2008
Posted on Jun 26, 2008
PLEASE ANYTIME I CHARGE MY IRIVER H320 AND IT GET FULL, I ONLY PLAY IT FOR ONLY 15 OR 10 MINUTE THEN IT GET OFF UNLESS I CHARGE IT AGAIN. CAN U PLEASE HELP ME SOLVE THIS FAULT. THANK U.
Posted on Aug 17, 2008
I have an error message in my iRiver and unable to use it anymore. The error message I'm getting is: Boot Failure System file has an error. To solve the problem, connect the device to compute
If it is an older model like H10, it used a a micro hard drive which may have failed mechanically. Those old hard drive devices were susceptible to shock failure due to drops. In some cases you may be able to replace the failed hard drive with a compact flash card - I believe they used the same connectors and pin outs. If it is not a hard drive model, can you get it recognized by windows drive manager to try to reformat it. There's a linux based program G-Part Ed. It's an ISO file, burn to cd or put on USB and boot pc to the cd or usb to launch linux and the software then see if it will recognize and format it as an external drive. Gibson research used to make spin rite that was able to fix some hard drive problems, might work on flash memory too.
Jan 02, 2015 | iRiver Audio Players & Recorders
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
Feb 22, 2011 | iRiver E10 Digital Media Player
Does not open the iriver E10
Hard drive connection on iRiver H320
i have iriver it show check hdd full whay i shold do
Dec 23, 2008 | iRiver H320 MP3 Player
Iriver says ''Check HDD Connection'' at initial boot up--
if you know some one with the same iriver...you can copy thier software (not music) onto you pc / laptop....disconnect & plug your iriver up...now you can format your iriver..copy the software onto it...its like starting fresh now.......but if no one is around w/ an iriver..you will have just purchase another one ...(if purchase hard drive you will still need the software)...
http://shop.ebay.com/items/?_nkw=TOSHIBA+%28hard+drive%29+1.8&_sacat=0&_trksid=p3286.m270.l1313&_odkw=TOSHIBA+MK3006GAL+30GB&_osacat=0
Nov 17, 2008 | iRiver H320 MP3 Player
Iriver H300 problems
http://www.misticriver.net/forums/h3xx-series-320-340/11314-fixed-h320-always-connected-prob.html
May 31, 2008 | iRiver H320 MP3 Player
HDD not recognised
I am not an expert, but the same thing happened with me and that's because the bit connecting the motherboard to the hardrive has been damaged, so may be the same for you....
Mar 02, 2008 | iRiver H340 MP3 Player
Iriver 320 HDD Connection
suggestion only, open it up and check the hdd connection. failing that, your hard drive is probly naffed
Sep 01, 2007 | iRiver H340 MP3 Player
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
iRiver H320 MP3 Player Logo
566 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
