Question about Krups Allegro FND111 Espresso & Coffee Maker
Steam frother nO STEAM IS COMING OUT
  • Anonymous Apr 04, 2009
    no steam
    Problem Solver:
  • 4 Answers
1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for the machine for an hour. 4. Remove sheath from the steamer. 5. Place tip of steamer into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through steamer.
Optional: Before starting the process, unbend a paperclip or metal hook (for hanging holiday ornaments) and use it to clear the steamer orifice.
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Posted on Apr 05, 2009
5 Suggested Answers
  • 2039 Answers
SOURCE: Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Posted on Jan 19, 2008
  • 5 Answers
SOURCE: gaggia classic -no steam from spout
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Posted on Jan 14, 2009
  • 37 Answers
SOURCE: Frother not working
The frother does not have a vacuum, it uses venturi pressure to draw up milk through a venturi at the top of the steam feed. The milk side is clogged from not cleaning enough. soak in boiling water for a few minutes and try to run it in steam mode for a while... if that doesnt work, a light lye solution will dissolve the milk residue clogging it. neutralize the lye with vinegar drawn through after the clog is gone.
(lye will dissolve you as well as milk... use gloves and don't put your face near it while it's working.)
Posted on Apr 19, 2009
SOURCE: plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
Posted on Apr 27, 2009
More detail to my question on mal function of milk frother. Coffee making function is working well and I have descaled as per instructions. When I try to use the steam arm there is a pumping sound but...
This might not be the problem , but sometimes , not cleaning milk frother tip properly , the tip gets closed with dry milk. use a needle and push it in the frother tip and see if there is a restriction. hope this helps.
Mar 22, 2015 | DeLonghi Pump Espresso Maker
No steam from Magimix expresso
Has anyone got a solution to no steam from milk frother please
Dec 12, 2011 | Magimix L'Expresso Espresso Machine
Ventilate!....shows in window and machine will not ventilate when knob is opened. it has regularly been de-scaled but we do live in a hard-water area.
Generally you can clear the ventilate error by pressing the button for Hot Water and then opening the steam knob. You should hear the pump run and water should start to flow from the steam wand. If it doesn't, try removing the frother nozzle so just the chrome pipe is showing.
To remove the frother nozzle you slide the outer sleeve off, and then grip the nozzle with one hand while twisting the cap to loosen it. Then it should slide off the metal steam pipe. Or you can check that the tip of the nozzle isn't clogged.
If you have the frother removed and the steam pipe is definitely open and not clogged and you still hear the pump running but no water is coming out, the next step is to prime the pump.
If you still have the squeeze bulb pump that came with the machine, you can use that - or if you don't have it, a turkey baster will work. You want to take the water tank off and set it aside, then pump water into the valve in the center where the tank had been sitting. You choose "Hot Water" and open the steam valve so the pump starts and then pump water into that valve with the Turkey Baster. You should hear the pump catch and start to move the water - when this happens immediately close the steam valve so the pump stops - then replace the water tank (filled with water please) and open the steam valve again and let water run out of the steam wand for several seconds.
That should clear the ventilate message.
Oct 21, 2010 | Gaggia Titanium Espresso Machine
Ventilate message, then no steam coming out
Sounds like you have an internal blockage in one of the boilers.
Take it to your local service agent for repair.
Did you remove the milk frother and try the hot water again?
A blocked frother is a very common problem .
Feb 24, 2010 | Gaggia Titanium Espresso Machine
How do you clean the frother on the ESP8XL machine?
1. Remove the froth enhancer and rinse under warm tap water. 2.. Wipe the steam wand with a damp cloth. 3. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand. If that doesn't work, remove any rubber parts. Place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile.
Nov 08, 2009 | Breville ESP8XL Espresso Machine
No water or steam is coming out of the frother. Tried rinsing machine and going back and forth from brew to froth with no results.
Just fixed this same problem by taking apart the water solenoid valve and cleaning out its connection tube of deposits that was blocking water/steam flow. I removed the magnetic coil but that's not required. The connector was very tight because it had loctite sealer on the threads. I used plumbers teflon tape on the threads when reassembling.
May 11, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Saeco Royal -No water is coming out of milk frother and water underneath machine
Yes- specially if you see "white scaling around it". If machine not regularly descaled, this can happen. For part and or customer support contact
Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at :
Mar 04, 2008 | Saeco Royal Professional Espresso Machine
Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Nov 20, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups Allegro FND111 Espresso & Coffee Maker Logo
581 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
