Question about Dell Latitude D820 Notebook
F5 key came off and is in 3 pieces- Help
Help!!
  • 130 Answers
What computer name and mo. do you have?
Posted on Jun 19, 2008
HOW DO I KNOW IF MY VGA PORT IS ENABLED?
Press, and hold down on the Fn key, and AT THE SAME time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no?
There are at least 3 display options;
1) Internal monitor of laptop ONLY.
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F5 key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | Acer Aspire One Netbook 8.9" Notebook
No video signal from hmdi connection laptop to tv
Your laptop has at least 3 display options;
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external display device
3) External display device ONLY
Press the Fn key down, and hold it down. Tap once on the F5 key.
(The F5 key is the Display Toggle-Over key)
Still no? Hold the Fn key down again, and tap once more on the F5 key.
Also make sure the HDTV is set.
Regards,
joecoolvette
Dec 15, 2012 | Acer Computers & Internet
My screen went white, how can I fix this?
Don't freak out!
You just tapped the Display Toggle-Over key.
Hold the Fn key down, and at the same time tap ONCE on the F5 key.
Still no?
There are at least 3 display options for your laptop, Shivam;
2) Internal monitor of laptop AND external display
3) External display ONLY
You set it by accident to external display ONLY.
Regards,
joecoolvette
Aug 18, 2012 | Acer Aspire Computers & Internet
My hp tc4400 will not start up, I can hear the fan and the green button flashes any help would be great
Try pressing the fn key and F5 key together at the same time.sometimes the sticky keys just seem to kick in. if not F5 key it will be one off the other F keys dont forget fn+ F5 or other.
hope this helps
Aug 17, 2010 | Compaq tc4400 Tablet PC
My sharp (AR-5316) has appearing a F5 so it can't process my documents so what i suppose to do? please can you help me
F5 is exposure lamp problem, to fix this problem try these solutions:
Solution1: switch off and on the machine.
But if this is not working try solution 2
Solution 2:
Step1: Press continuously Clear key then Interrupt key then Zero key then Interrupt key
Step 2: You are inside the simulation if the display turns off but if not do again step1.
Step 3: Press 14 then press print button
Step 4: If not canceled try step 1 to step 2 again then press 16 then press print button
But if this is not working try solution 3
Solution 3: try to open the platen glass and clean the mirrors and also the bottom side of the platen glass especially the white correction plate then apply solution 2.
Oct 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have pressed Fn and F5 on my easynote laptop now the LCD screen has gone wierd. How do I reverse this?
fn + F5 changes output mode
its 3 way toggle switch
1. laptop screen only
2. secondary display unit only\
3. mirror on both display units
press Fn+f5 keys again to revert to normal mode
Apr 04, 2009 | Computers & Internet
Fn F5 key in my Travelmate2310 stopped working
Was Fn+F5 working before? Why do you 'have to use with external display", because LCD no display any more or...?
If non above, you better check from BIOS and chang display to Both LCD and VGA.
If Fn+F5 was working before but not now, could be something else wrong... I need know more details....
Nov 12, 2008 | Acer TravelMate 2300 Notebook
Monitor hibernation.
Any key! This may help if its a display setting problem:
Fn & F5 simultaneously, cycles the display output through the 5 modes. (hold the Fn key down, and press the F5 key, press it again, give it time to change before you press it each time)
the 5 modes are:
1.built in display only.
2.built in display AND external monitor.
3.External monitor only
4.built in display and TV
5. TV only
*note: Internal display resolution must match external display resolution, and that resolution must be
at least 800X600, or higher
Apr 02, 2008 | Toshiba Satellite A135 Notebook
Panasonic FP-7735 won't recognize paper tray
Can you hear the tray rise when you close it? Is there a red, blinking "out of paper" light on the control panel? Can you select the tray manually?
Or, you had a power outtage, or gremlins, and the settings reset itself, you can go in to service mode and set the trays up again.
Hold the following keys to fire up Function mode. "Function + Original Size + 3". Hit 5 for F5 mode. F5-14 is tray 1. If you have a duplex(ADU) unit installed, you'll want to check out tray 2. F5-14 is tray 1, F5-15 is tray 2 all the way down to F5-18.
Key in whichever number you need.
0: none (no tray installed)
1: Ledger
2: Legal
3: Letter
4: Letter-R (landscape)
5: Invoice
Jan 24, 2008 | Panasonic FP-7735 Black and White Copier
Dell Latitude D820 Notebook Logo
26 people viewed this question
Alun Cox
