Question about Pitco Frialator 35CD Deep Fryer
Pitco fryer pilot out
Changed thermopile, pilot will not stay lit had correct part
  • burzerko
    burzerko May 11, 2010
    Does this fryer use a pilot safty valve? It will have a red dime sized button on it.
    Champion:
  • 254 Answers
If you changed the thermopile and still have the same problem make sure that the sensing bulb is directly over the flame. If it is and the thermopile is installed correctly the next thing would be the gas valve.
Hope this helps
Posted on Jun 22, 2008
The problem is the thermocouple , and not the gas valve or thermopile
Posted on Feb 12, 2009
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot light does not stay on
Hi there.
Try cleaning the thermopile, it must be free of soot or any form of dirt. Ensure that the gas pressure is sufficient, all wiring connections are tight and the hi limit is good.
If all of these are okay and the pilot still wont stay lit, try replacing the thermopile.
For Owner's manual download that will help you in minor fryer troubleshooting and reference, visit http://www.pitco.com
Regards.
Jun 27, 2011 | Pitco Frialator 35CS Deep Fryer
Fryer wont stay lit, only two burners will lite, and will only stay lit for about 5 min. will then go out and must start over
Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
Jun 15, 2011 | Pitco Frialator E24 Deep Fryer
My pitco frialator of 1976 vintage will not fire up although the pilot light stays lit
Try to check if the thermopile is receiving enough heat from pilot flame and is free from dirt or carbon deposit. If not so, try to make adjustments or clean the thermopile.
Apr 04, 2011 | Kitchen Appliances - Others
Pilot light keeps going out! Will not stay Lit.
Check if the the gas pressure is sufficient (as stated on unit's nameplate). Check if the hi limit device is good. Check also if the thermopile (cylindrical metal with two wires standing behind the pilot hood) is receiving enough heat from the pilot flame. The voltage generated by thermopile should be 500millivolts in order to open pilot and main valve. If there is 500millivolt on gas valve thermopile and the pilot flame does not stay lit, you have to replace the gas valve. If the thermopile is glowing red and the voltage generated does not reach 500 millivots, you have to replace the thermopile.
Jan 18, 2011 | Pitco Frialator SG18S Deep Fryer
We changed the thermostat in our unit and now the pilot lite won't stay lit!
You have to check the following:
1. Does the pilot flame has the ability to heat up the thermopile? Themopile must be properly heated in order to generate voltage to open the pilot valve as well as main valve.
2. When the thermolpile is heated, does it generates 500 millivolts? If not, your thermopile needs replacement. If it does and still the pilot flame wont stay lit, your gas valve needs replacement.
3. Does the hi limit device has continuity on its terminals? If there is no continuity on hi limit terminals, you have to replace it. One of the thermopile wire passes on this hi limit terminal to cut the voltage supply on pilot valve in case the oil temperature reaches 450F.
4. Check and tighten all wiring connections, millivolts generated by thermopile will not pass on loosely terminated wiring.
Jan 12, 2011 | Pitco Frialator 35CS Deep Fryer
My pitco frialator fryer's pilate wont stay lit
Check the thermopile, it should be free of soot or any form of dirt. Pilot flame quality must be good. Gas pressure should meet the requirement as stated on the nameplate.
Oct 22, 2010 | Pitco Frialator 35C Deep Fryer
I have a used sg-14 pitco that i want to use outside for my family reunionsdo i have to use a large tank oflp or can i use a 30-lb tank when i light the pilot it will not stay lit when i release the button...
You can check the voltage generated by thermopile using a voltmeter. Set the voltmeter on milli-volt setting then heat up the thermopile. When properly heated, it can generate 500 to 750 milli-volts.
May 20, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Fryer will not light up
Check the thermopile, it must be free of dirt or soot so that it can absorb enough heat from pilot flame and in turn can generate the right amount of voltage to energize pilot and burner coils.
Check also the gas pressure, it should be of standard as required on the unit's nameplate.
Apr 15, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator 35CD Deep Fryer Logo
404 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
