Question about Samsung YP-K3 MP3 Player
1999 Ford Exploer
I am trying to get the spark plug firing sequence for a 199 Ford Explorer 5.0.
  • 8,596 Answers
Way wrong section - you will never get an answer by posting a car question in an mp3 player forum
Posted on Jun 26, 2008
Change my spark plugs and distrubutor cap and the 85 ranger want start
You may have got the spark plug wires out of sequence.
Reseat the coil wire going to the center of the distributor cap Check the spark plug wires at the distributor against the firing order as follows:
The spark plug firing order is 1 - 4 - 2 - 5 - 3 - 6 The distributor rotor turns CLOCKWISE The engine cylinders / spark plugs are numbered :
firewall 3 - 6 2 - 5 1 - 4 front
Best wishes,
TF
Jun 03, 2011 | 1985 Ford Ranger
95 ford explorer spark plug firing order
1995 Ford Explorer 4.0 liter SOHC V-6 VIN "X"
1995 Ford Explorer 5.0 liter V-8 VIN "P"
Hope helps (remember rated this).
Jul 13, 2010 | 1995 Ford Explorer
Firing sequence for 1999 ford explorer ...(changing spark plugs)?
if you are not sure what goes where with the ht leads why not tie a lable to each one or only change one at a time......say left bank then right bank....you do not have to take all the leads off to change plugs.
Jul 12, 2010 | 1999 Ford Explorer
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
Spark plug wire sequence foor a 3.1
No 3.1L but choose the one that is yours.....
2.5L Engine Firing order: 1-3-4-2 Distributor rotation: clockwise
1999-04 4.0L Engine Firing order: 1-5-3-6-2-4 Distributorless ignition system
4.7L Engine Firing order: 1-8-4-3-6-5-7-2 Distributorless ignition
5.7L Engine Firing order: 1-8-4-3-6-5-7-2 Distributorless ignition
Oct 09, 2009 | 2002 Jeep Grand Cherokee
Distributor wiring sequence
Chilton manual at Autozone has this info.
Sep 25, 2009 | 1999 Ford Explorer
What is the firing order and spark plug connection?
4.0L OHV Firing Order Firing order for the 4.0 liter OHV V6 is
  • 1-4-2-5-3-6
4.0L SOHV Firing Order Firing order for the 4.0 liter SOHV V6 is
  • 1-4-2-5-3-6
5.0L Firing Order Firing order for the 5.0 liter V8 is
  • 1-3-7-2-6-5-4-8
How to Find the Cylinder Order V6 When standing in the front of the vehicle the cylinders are numbered 1-3 up the passenger's side and 4-6 up the driver's side. How to Find the Cylinder Order V8 When standing in the front of the vehicle the cylinders are numbered 1-4 up the passenger's side and 5-8 up the driver's side.
Jul 30, 2009 | 1999 Ford Explorer
Wiring order
Since your distributer cap spins in a clockwise motion, just make sure you start with 1 then 4, then in the full order to make sure the sequence is correct.
May 26, 2009 | 2004 Ford Explorer Sport Trac
1999 ford explorer misfire in cylninder 6 code
you might try changing the engine coolant temp sensor. could also have defective spark plugs. check the fuel filter, lines and pump.
Apr 09, 2009 | 1999 Ford Explorer
Samsung YP-K3 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
