Question about RCA P46924 46" Rear Projection Television
Tv turns on then goes off by itself
I am having the same problem someone else is having with they TV about when I power it on, I hear static, then it turns back off itself, I wonder why its doing that, well now that I done let it sat up, I am not getting more power to the TV, i let a tv technician checked the fuse to it, they said it still works fine, the fuse itself, well the TV do not come on anymore upon pressing the power button, so now what could the problem be. I hope it do not need a picture tube.
  • bking27 Jun 20, 2008
    oh uh huh so thats what the problem could be, well I'll try to do that one day. uh do you have one of them TV's by the way I shall ask. I am glad I havent discard that big TV, cause I thought I might could get it to working after someone gave it to me. If I get it to working before this new digital television stuff starts next year, I am gonna be so excited to have a big TV in my room until I am not gonna know what to do. yeah it sure aint getting no power at all when I plug it into the wall outlet. at first it used to, but not anymore, nope. so thanks so much for ya reply. so its the power supply section, okie dokie. thanks a million. so u think that the picture tubes in it could still be some good, it doesnt seem like anything is wrong with them. so it might needs some new soldering to the power supply. can you tell me how to do it, I do not have a soldering iron or gun whatever ya call it, I sure dont. so give me some good ideas, tips, suggestions on how to do it, ok. thank ya so much.
  • 2,071 Answers
The problem is in power supply section.,it need to reheat all that section so performance become normal again...
Posted on Jun 19, 2008
  • LORETO LACARON
    LORETO LACARON Jun 20, 2008
    that is the problem if you dont have the knowledge to solder because it will be damage ,,when it short circuited to the parts ...The only thing that i suggest thatlook for a TV repairman who will able do the repair or bring it to the service center..if my answer helps you to understand the problem rate me as fixya....
  • RCA Master
  • 8,617 Answers
Try resoldering the flyback connections and look the board over real good for cold or cracked solder. Cold solder appears dull instead of shiny and cracks are often nothing more than a very small ring around the pin connection
Static on Powering on
You can start out by resoldering all poor solder connections and look for bad capacitors they will be puffed up on Top.
Oct 01, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No audio...only static
This is caused by a corrupted signal being sent out by one of the stations you are watching. There is definitely NO PERMANENT SOLUTION to this problem. Just keep unplugging the TV.
May 13, 2009 | RCA P60921 60" Rear Projection Television
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Not coming on
Hello Lizzy48. I'm sorry to inform you but from your info you may have a flyback problem. This could be a power supply failure as well but as I mentioned from previous experience your High Voltage Flyback Power supply has a problem. If you have experience in electronic repair you may aquire someone to guide you in the repair to componet level or option #2 call a local TV repair shop for estamates. Good luck.
Sep 24, 2008 | RCA D61130 61" Rear Projection Television
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
No picture or auido.
Place your ear near the back of the tv and have someone turn the unit on. If the following occur :
a.) If you hear a high pitched whining sound and the fan trying to start but the unit fails to start and goes all quiet it could be a bulb issue. (see owners manual for trouble shooting code of blinking power light in front of tv)
b.) you hear nothing. It may be that the power supply for the unit has failed or its fail safe fuse has tripped. ( call tech this one needs a pro to sort out )
c.) seems like its trying to restart itself but does not quite make it. ( its a bulb issue check owners manual )
Jan 05, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
RCA P46924 46" Rear Projection Television Logo
451 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
