Question about Cuisinart Thermal DGB-600 Grinder
Noise My DGB-600 grind and brew coffeemaker starting making a beeping noise and only way to stop is unplug it. What is this and how do I correct it?
  • Anonymous Apr 08, 2009
    The saem annoying beeping was plaguing me! The idea about the plunger on the top lid was the culprit. In lieu of toothpicks i used the end of an inscense, and BAM works like a charm.
The top of the unit that covers the coffee beans has a plastic point that must depress a button on the main body of the unit when it closes to show the unit that the lid is closed properly. If this is broken (as was mine) I inserted the end of a piece of tooth pick replacing the plastic point in the lid and this now depresses the recessed button on the main unit. The beeper goes off and the on light comes on.
Posted on Feb 15, 2009
  • ajkmsteph2 Feb 15, 2009
    You also need to put the bean grinder cover in place correctly
  • 515 Answers
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
Hope this will help you.
/Mirran
Posted on Aug 12, 2008
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Grind Off lamp blinks continuously.
An extended power off period remedied the situation.
Mar 19, 2009 | Cuisinart DGB-600 Coffee Maker
I just purchased a dgb 550 series 2 days ago, I was moving it and it is now making a beeping sound and will not allow me to do anything, I have unplugged it and replugged and it still does this I tried to...
The constant beeping means that something is out of place - make sure the charcoal water filter holder is in place, even if there are no filters inside. Make sure the grind chamber and all parts are in place. Make sure the filter basket is in place, and that the door is closed. Finally, make sure the lid of the coffee maker tiself is shut and that the lid of the craffe is firmly in place. If everything is in place, it should stop beeping. Turn the coffeemaker off, and then on after all of this is done.
Mar 08, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I cannot remove the grinder from my cuisinart Grind and Brew Coffeemaker. It still makes great coffee, but I want to clean the grinding mechasim and cannot remove it.
Common with the DGB-600 - you can try icing it down for 10 minutes - once removed, clean exterior with vinegar applied to a rag to get oils off - endemic to this unit - replacing it with exact same model will not help.
Oct 13, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
DGB-600 grind & brew thermal coffeemaker
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
DGB-300 10 cup grind and brew
The constant beeping means that something is out of place. Take apart the coffeemaker parts completely and put them back in their proper place (don't forget to close the lid). The beep should stop. If it doesn't stop, unplug the unit for one hour and call Cuisinart to see if it is still in warranty.
-Tha Mp3 Doctor
Dec 17, 2007 | Cuisinart DGB-300 Coffee Maker
Automatic Grind not working
My grinder was not working properly, because the blade was not rotating freely. So we carefully chipped away some caked on coffee residue. Then it worked for awhile, but started to sound weird and only partially grind the coffee. So we applied a small amount of vegetable oil to the blade and let it seep down a little, and that was very succcessful! Just needed a lube job!
chrisnap49
Oct 23, 2006 | Cuisinart DGB-300 Coffee Maker
Cuisinart Thermal DGB-600 Grinder Logo
221 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
