Question about DeLonghi PAC85 Portable Air Conditioner
Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
I have a Delonghi Pinguino Classic Portable Air Conditoner (Pac 85 I think) works for about 30 min then red light goes on. have to use red reset button on back of AC to start it up again. It works for 30 min but red light turns on again then has to reset. Can you please let me know what is causing the problem and if I can repair it myself or take it to an AC repair shop.
  • jpphotograph Oct 02, 2008
    Thanks for the tip!
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
  • Brenda Reid Sep 27, 2012
    It weighs about 300lbs and we live in a 3rd storey walk up.Fixing it is simple if I coud remove the body. I have taken out all visible screws but have been unable to remove the plastic casing.
I have a delonghi pinguino classic pac 25 i have to keep reseting red button on rear after aprox 2-5 mins as compressor cuts out &does not seem to restart but fan keeps going & red light with !...
Yes, bought one today, everything was fine until I put water in the tank, then it stopped after about 3 min. I think you will find that the previous owners (assuming 2nd hand) haven't de-scaled it. Take the rear cover off 5 self tap screws & you should see a lot of scale (calcium) you have to clean this away by whatever means you have (a hose nozzle) try not to wet the electrics too much. I had a wet vacuum aqua-vac I think &that helped but you can still do the same thing by hand, once it's fairly clean, it should run right, if i'm not wrong there will be a lot of calcium on the lower heat exchanger, you have to take off the plastic cover (2) self-tap screws & you will see what I mean, just scrape it away with the end of a toothbrush, no the end you hold, see you Richard
Jan 30, 2011 | DeLonghi Pinguino PAC-77E Air Conditioner
Air conditioner Pinguino PAC CT110 DeLonghi. I need the manual for the owner. THANKS
Try with this site;
www.manualnguide.com/manual/delonghi-pinguino-portable-air-conditioner-manual-pac-ct110/ -
Helpful?
Dec 29, 2010 | Heating & Cooling
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Feb 14, 2009 | DeLonghi Pinguino PAC-210 Air Conditioner
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Feb 14, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
FE Light
You need drain the water and then function normally.
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC85 Portable Air Conditioner Logo
2,537 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
