Question about Onkyo Audio Players & Recorders
I have a Onkyo 805 Receiver that while I was listening to DVD Video in DTS Mode the sound stopped and the TV went to input. I noticed the Display on the Receiver said E2PROM ERROR. Now I can't get anything to work. Receiver turns on then goes to the correct input but says DSP on the display and stays in all channel stereo analog. I tried pulling the powercord out for 5 minutes. Reset the 805 to default. Still when I turn the receiver on I get E2PROM ERROR then it switched to the right input. I have the latest firmware and have had the receiver new for a couple of months with no problems. Maybe I'll have to check all the speaker connections since I can't seem to get any 5.1 multichannels. Point me in the right direction please. My EMail address is ljc104u@msn.com if you need it. Larry
  • 151 Answers
WILL TRY TO GET A SOLUTION FOR YOU IN MORNING CALL ME ON 02870342354 LARRY. I HAVE NOT SEEN THIS ERROR BEFOR AND I SELL ONKYO IN THE SHOP I WORK IN,(LIGHTING,SOUND,AND VISION) IN NORTHERN IRELAND OR EMAIL ME AT LSVNI@YAHOO.CO.UK
RICKY.
Posted on Jun 20, 2008
I have a onkyo tx-sr507 and it works great the only problem is the setup feature for the unit doesn't show up on my tv it only shows up on my receiver can anyone help me figure this out my cousin has...
A simple composite video connection from its Monitor Out to the appropriately-selected input on your TV may resolve that.
Or, from the manual...
"While the Pure Audio listening mode is selected, the video circuitry is turned off and only the HDMI OUT outputs video signals."
Jul 12, 2011 | Onkyo Tx-sr507 A/V Receiver
No sound in listening modes except pure audio and direct. Was working fine and just stopped one day. Connections are all good. Surround sound seems to be broken?
Check the input mode on the reciever so that they are set for dual, rather than just digital or analog. It might be set for analog and your using a digital optical in cable. Also make sure DTS mode is turned off, unless your watching a DVD that is dts enabled.
Aug 06, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Listening mode functions lost one by one
It needs service. Not worth repair though.
Jun 09, 2009 | Onkyo HTR500 Receiver
Rear surround speakers quit working from my Onkyo
It looks like the audio output was changed on the player so that it doesn't output 5.1. Enter the setup menu on the player and change DTS to output DTS instead of what be labled as stereo or L/R and Dolby Digital to output Dolby Digital instead of whatever else it is set to.
Jun 05, 2009 | Onkyo HTR500 Receiver
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
May 07, 2009 | Yamaha HTR-6130 Receiver
Onkyo tx-sr806 reciver ''DTS HD''
hdmi connection between player and AVR. Right?
I am sure you would have also done the first time setup and set all the 7 speaker as well as the subwoofer thru your auto or manual speaker set up and that the reason you are getting Neo6.
On your Receiver, please also check the format of the digital input signal thru "Displaying Source Information" Press the [RECIEVER] button, and then press the [DISPLAY] buttorn repeatedly to cycle thru the available information.
a).. If the information shown say that DTS - ES Discrete, DTS- Matrix, DTS -HD and so on.... then we need to check as to why the receiver is not accepting the signal.
b).If the information shows otherwise and a 7.1 signal is not availalbe, then its possible that the source(in this case the BD player/or the recording is not sending the required signal).
lets take the case (a). In this case if you have all the 7.1 set up in place and you are getting the required signal , then you can assign a default listening mode to each input source that will be selected automatically when you select each input source.
Press [RECEIVER] button followed by [SETUP] button and enter listening mode setup, use up , down buttons to select the input source that you want to set and press [ENTER].
then use [up], [down] button to select the signal format that you want to set.
then use the [[LEFT] and [RIGHT] buttons to select a listening mode.
When you are finished, you can press [SETUP] again.
The above is with experience with ONKYO AV Receivers. In case you have a problem , please let me know so that I can go thru the SETUP menu of your particular receiver i.eTX-SR- 806.
HOpe the above sort out. DO let me know.
Please do rate this solution and thanks for using FixYa!
Mar 05, 2009 | Onkyo TX-SR803 Receiver
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
Onkyo receiver TX-DS696
If you get sound on direct mode say from dvd but no sound when you go to dolby make sure you have the right input selected by pressing the digitat input button on the front of the amp,ie if dvd optical out is pluged into amp optical input 1 select this on amp then set audio to prologic2.DVDs through this input will decode to dolby digital/dts.
hope this helps.
CABLE GUY.
Jun 25, 2008 | Audio Players & Recorders
Surround mode
have you turned it on from the dvd menu the easist way to tell if you have is there will be little speakers that light up on your amps screen (more than two) when the movie is playing (not The menu) Not all movies are encoded in DTS hopefully this helps
Apr 02, 2008 | Onkyo TX-DS575 Receiver
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
580 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
