Question about Lexmark X8350 All-In-One InkJet Printer
Lexmark 8300 print/scan/fax
I am having problems faxing and scanning. When I send a fax it comes out illegible at the other end. Sometimes only half the page scanned and the remainder is blank, or there are big black blotches on parts of the page at the receiving end. Also, last week I couldn't send a fax at all. It just kept trying to send, but it would never go through. I know the fax number, etc. is operating and correct because it's a fax I fax to several times a week.
Thanks.
  • alwayson1213 Aug 17, 2008
    When i try to copy something it only scans a half the page and prints one quarter of the page.
  • r-gavula May 11, 2010
    need to down load driver for lexmart X8300 aLL IN ONE
  • 33 Answers
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Posted on Jan 04, 2009
Once a doc is scanned on a 8300 series all in one, how do I get the scanned image from the printer to a word doc? Looked
You can actually scan directly to an application(ex. MS Word application). Also, make sure the Lexmark OCR scan software is installed on your computer (the software is available on the install disc that came with your printer).
1. Load an original document into the ADF or on the scanner glass. 2. Press Scan Mode. 3. Press ? or ? repeatedly until the MS Word application is highlighted. 4. Press check button. 5. Press Start Color or Start Black to start scanning.
Source: Lexmark 8300 Series User's Guide page 72.
May 14, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I can receive faxes but when I send them they are illegible.
make sure glass is totally clean and pad is clean, also could be an issue with your scanner bulb
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
There are verticle lines when faxing, copying, and scanning.
This print defect can be caused by a foreign object or substance on the outside of the scanner assembly, usually located on the plastic cover that the paper passes over.
Lexmark Printer
If the scanner is clicking than it is a scanner issue. Make sure there is not a lock button on the machine. They sometimes have these for when the printer is being moved. As for the faxing software it would seem that that part didn't not get installed so if you can update it.
Apr 01, 2008 | Lexmark X1270 All-In-One InkJet Printer
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
When I fax docs, it is received with stripes and stains
first check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
Jan 29, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Lexmark X8350 All-In-One InkJet Printer Logo
292 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
