Question about Garmin nuvi 350 GPS Receiver
N?vi 350 I have the same problem with the Garmin n?vi 350, may be you can help me? Your text: Under Settings -> System -> About, you can read "GPS SW Version: 0.00s" I tested the Software Version 4.10 with WebUpdater and the Software Version 3.40, that I have receive from the Support.
    Scholar:
  • 174 Answers
Mumbo jumbo....use the webupdater, check the firmware and voice/text you need, the web updater will download them to the nuvi, when downloaded webupdater will tell you, unplug the nuvi and wait patiently for it to reboot about twice....finished.
Posted on Jul 23, 2008
I recently updated maps. Since that time the voice prompt does not work. Please give me trouble shooting information. Thanks, susan
Go to Tools..... Settings....Language... under Voice tab select one that has an ending with ( TTS ) text to speech
Nov 22, 2010 | Garmin Nuvi 350 Car GPS Receiver
Change from spainsh to english garmin 265 wt
Press the spanner symbol (Tools)
Press SETTINGS (or LOCALE if your model doesn't have settings)
Press LANGUAGE (The lips icon)
You'll see a screen with 3 icons, one for VOICE, one for TEXT LANGUAGE and one for KEYBOARD
If you need to change the voice language press the VOICE icon and select an English voice
If you need to change the text language press TEXT LANGUAGE and select English.
Oct 12, 2010 | Garmin n?vi 265WT Car GPS Receiver
My 265 wt gives directions, but does not name the street
if its an old model it may not had "text to speak" if it has "text to speak" the function is switched off, in witch case switch it on in settings, also some roads are not recognised
Jan 03, 2010 | Garmin n?vi 265WT Car GPS Receiver
System software missing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
May 15, 2009 | Garmin n?vi 265WT Car GPS Receiver
How do I reset garmin 205 w
Resetting Your nüvi 205W. PLEASE READ ALL BEFORE TRYING.
If your nüvi stops responding, turn the nüvi off, and then turn it back on.
If this does not help, reset your nüvi.
Press and hold the RESET button on the bottom of the nüvi for several seconds.
Clearing User Data CAUTION:
This deletes all user-entered information.
1. Hold your finger on the lower-right corner of the nüvi screen while turning on the nüvi.
2. Keep your finger pressed until the pop-up window appears.
3. Touch Yes to clear all user data.
All original settings are restored.
Any items that you have saved are erased.
Let me know if it solved it.thxx
Jan 12, 2009 | Garmin nuvi 205W GPS Receiver
Garmin 300 stopped talking and I can not find the fix problem at garmin.com, garmin.co.za or garmap.co.za. How do I repair
on menu touch settings, voice languages,
Languages noted with TTS are text to speech,
Regards.
Aug 25, 2008 | Garmin nuvi 350 GPS Receiver
N?vi 350
Turn on the unit and go to Settings
Then select Map
Then select Map Info
Verify that there is a check mark next to City Navigator North America NT
May 20, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 260 - how to activate text to speech
Question: How do I change the Voice Language setting on my nuvi 2xx?
--> Answer: All of the Garmin® automotive GPS units that speak street names are also loaded with basic voice prompts (example: Turn Right in 500 feet) as well as Text-to-Speech (TTS) voices that speak street names. If one of the basic types of voice prompts has been selected, the voice prompts will not speak street names. In order to change this setting on the nüvi® 2xx series, follow these steps:
  1. In the Main Menu, touch Tools (Wrench icon).
  2. Touch Settings.
  3. Press the Down arrow in the bottom right corner.
  4. Select Language.
  5. The first line on this screen is the Voice language. Touch the Current Voice option for the GPS device listed to change the Voice.
  6. Select a Voice that is labeled TTS. These will speak street names. Options without the TTS label will say the distance until the next turn, but will not include the street name.
  7. Select OK. The Voice has now been changed.
The device should now speak street names. This is tghe solution that I found on the Garmin site. It worked for my device. Hope this is helpful. solution = solution1description.innerHTML; Last modified on: 04/14/2008
--> Other recommended links Next Solution >> nuvi 260 nuvi 255 nuvi 200 nuvi 270 nuvi 205W nuvi 260W nuvi 250 nuvi 250W nuvi 255W nuvi 205 nuvi 200W -->
Dec 28, 2007 | Garmin nuvi 350 GPS Receiver
Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Nov 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
106 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
