Question about Whirlpool ED2SHGSM Side by Side Refrigerator
Model is ED2NHG
Freezer is barley cold but will ot freeze. Refrig., is barley cold....it is only 5 years old....Help
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
  • 19 Answers
SOURCE: GE refrig side by side 7-8 yrs old will not freeze frig not cold
Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
Posted on Jun 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Posted on Jun 20, 2009
projdoc
  • 2237 Answers
SOURCE: Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 28, 2009
SOURCE: Hotpoint hss25gfphww refrigerator is not cooling
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
Helloi have a Maytag Plus side by side refrigerator (about 10 years old) and I'm having trouble keeping the refrigerator side cold enough. This unit has dual slide bar controls on the ceiling of the...
remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Jul 19, 2010 | Refrigerators
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
New Refrigerator Past Warantee Not staying cold
is the fan in the freezer running? if not then the air cant circulate and nothing will cool properly. if is running, is there frost build up on the inside back wall of the freezer? if so you have a defrost problem. if no frost on the back and the fan is running, remove the back panel inside the freezer and make sure all of the silver coils have light frost on them. if only part of them are frosted get out your manual and look at the warranty section. then seal system may have a 5 year warranty. if it does then call sear for warranty service. if the coils only have partial frost and its not under a 5 year warranty buy a new frig. because repair will cost more than its worth
Nov 26, 2007 | Refrigerators
Whirlpool ED2SHGSM Side by Side Refrigerator Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
