Question about Tomtom ONE GPS Receiver
No GPS Signal
My tomtom gps is not operating. Keeps noting that there is "No GPS signal available"
  • mrprez624 Nov 08, 2008
    my tomtom keeps saying waiting for a valid signal
  • kjhalang Nov 09, 2008
    The Tom Tom 1 displays the poor GPS reception - are you inside a building note and S and W read 0 00.000
    despite showing 8 satelites above the black line and six of these to the max.
    None of which are turning blue.
    Is this a progeam problem
    We have reset the device and downloaded the latest updates but still no change.
    When the screen is touched with the finger the SW longitude/latitude readings disappear for an instant and return still reading 0
    apart from this tou can see the satelite bars and map on the circle changing, So the device is picking up signal,but the device is not responding or acting on the signal.respponding to these
    Brigadier General:
  • 4,090 Answers
Check port and baud rate
Posted on Aug 16, 2009
TOMTOM GO LIVE 2050 problem with TOMTOM Server
Have you been able to get satellite connections (signals) when you're outdoors ? and not under/around tall buildings or overhanging obstructions.
Regularly get QuickGPSfix update (using TomTom HOME) to download the latest satellite positions (for the next 7 days), to enable your GPS to find the satellites quicker.
Jul 17, 2013 | Tomtom GO GPS
My tomtom will not locate a gps signal
A software update fixing the issue is now available via MyTomTom. The update is straightforward. Simple instructions about how to update your device can be found at www.tomtom.com/386.
Apr 09, 2012 | Tomtom Via 1535tm GPS Receiver
Why is my gps losing its signal
Try connecting it to the computer and running an update from TomTom Home, there is a GPS fix that might help. Obviously the TomTom needs clearence to see the satalites in the sky otherwise try a hard reset with a pen in the bottom.
Jun 25, 2010 | Tomtom ONE GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Waiting for valid gps signal
The GPS needs at least 3 satellite signals to operate.You are probably in a bad reception area. Move around a bit and try again until you see a signal array of 3 or more!
Jun 30, 2009 | Tomtom One XL GPS Receiver
Tom tom one wont detect gps signal
my tomtom wont get a signal and is saying are you in a building?
Jun 18, 2009 | Tomtom ONE GPS Receiver
My tomtom cant find any satellites and keeps saying waiting on valid gps signal......
check the port is set to 8
not sure if your model has GPS search wher it finds the port and vbaude automativcally, if it does use it and see if that fixes it if not
your battery is too low
you have a damaged SIIRF chip and that is expensive to repair
Jun 01, 2009 | Tomtom ONE GPS Receiver
Tomtom keeps loosing GPS SIGNAL AND TAKES LONG TIME TO COME BACK
Plug in your tomtom and open my computer. Make note of the driver letter next to the tomtom symbol. Click Start, run (or search on vista or windows 7) and type in "CMD" without quotes and hit enter. a black window will open. type the letter you noted in my computer followed by a colon. Example: F: and press enter.
then type "chkdsk /f" without quotes and press enter. Answer yes to all the following prompts. once completed "takes less than a minute" type exit.
You can also try tomtom backup and then restore.
Apr 20, 2009 | Tomtom GO GPS Receiver
My tomtom keeps saying waiting for gps signal. was working perfectly, now wont pick up signal wherever we are
go to tomtom website ----> support ---->select product,
in the search box type in "lose signal",
click the "2. Updated - No GPS signal"
then follow instructions.
if it help rate the Solution Please
21/Apr/09
Apr 20, 2009 | GPS
Tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
Feb 11, 2009 | Tomtom GO 910 GPS Receiver
Tomtom ONE GPS Receiver Logo
59 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
