Question about Kenmore 98702 Stacked Washer/Dryer
Dryer won't start
Initially the dryer would not start. i tripped the breaker, tried it again and it worked. this was through the night so when i checked in the morning, the dryer had stopped before the clothes were dry (rare), and again it would not start. i tripped the breaker again but this time, nothing. can you help?
  • kccargallery Jul 10, 2008
    my dryer wont start i checked everything the wirering the plugs, brakers nothing seem to make it work. the washer is fine but i need for the dryer to work also. can you help?
  • justinbburn Aug 18, 2008
    I just moved to a new apartment and when I went to start the dryer, it would not start. Initially when I hit the start button, it made a noise like it was going to start, but then nothing. I have tried different settings and nothing. Occasionally it will make that first move, like it is about to start then quits.
  • 943 Answers
Thanks fore thew question i really think your problem is with your motor if you want to change the motor get back to me and i,ll show you how the other question i would look at the therml fue located st rear of dryer remove back panel you willl see 2 small blue wires thst part replace thanks thew appliance docj
Posted on Sep 14, 2008
No power to the display, dryer will not turn on
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Mar 13, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Circuit breaker tripped, i reset it and the dryer read PF, cleared that...but now the dryer just beeps when youy hit any button like start. The dryer is a kenmore h3 gas dryer
try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Oct 06, 2010 | Kenmore 82822 Electric Dryer
When i try to turn my dryer on, it won't start
Assuming that you have an electric dryer, check the house electrical panel dryer-circuit breaker-pair. Push both off, then on. If they immediately trip off again, then you have a dead short circuit within the dryer. If they hold on, then try the dryer--if works,ok! If it doesn't work, recheck the breakers again--if tripped, a short circuit in the dryer heater circuit is probable. The dryer drum must be removed to gain access to the heater assembly.
Aug 23, 2009 | Dryers
Dryer tripped breaker--shotgun blast sound
You may have a wire burn off the element and fall down to the base frame and cause a direct short. Turn you breaker off, remove the front and inspect for such a scenario.
Jun 02, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
