Question about Creative Labs ZEN Vision:M Digital Media Player
Only comes on when plugged into charger and then does not operate correctly only displays the Creative logo. None of the buttons work.
    Master:
  • 788 Answers
Hold the on/off switch in the on position as if you were turning the unit on then press the reset button with a paper clip next to the dock connector. Let go of the on/off switch and the player should reboot in the Recovery Mode. First try doing a disc cleanup to see if it resolves your issue. Next try doing the reload firmware from the recovery mode screen. If that still doesn't work and you don't mind having to re-copy your music to the player then try to format all.
It also sounds like your battery has died. Here is a link to buy a replacement battery: http://www.ipods99.com/ProductDetails.asp?ProductCode=CLZENVISION
Posted on Jun 19, 2008
When I press the button the only thing that will display is the time and then it turns back off. How do I correct this.
Make sure your Fitbit is fully charged by plugging it into its charger, it should vibrate and you want to see a fully white battery indicator when pressing the button.
While it is on its charger let's do a reset, by holding there button until you see the Fitbit logo.
Jun 01, 2015 | Fitbit Charge Wireless Activity Tracker...
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
I have a creative zen m vision which is not working if I try to reload firmware I get a message harddidk problem - how do I proceed
1 HD damage could be done when you drop the Zen and you hear noises inside, some times the display just shows the Creative logo and no more.
2 the display just show the Creative logo, no noises inside, you can tray to put in Recovery mode as mentioned in the other solution and then erase firmware then reload firmware, this firmware can be downloaded form creative page,http://us.creative.com/support/downloads/download.asp?MainCategory=213&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP&region=1&P
However
Before you go to all that trouble though try these steps:
1. Connect the device to the wall charger.
2. Hold the power switch to ON.
3. Put a paper clip into the reset hole.
4. Continue holding the power switch on until the Creative logo appears.
5. Select Format All from the Recovery Mode menu. (Note: THIS WILL ERASE ALL DATA FROM YOUR DEVICE! - but it's better than buying a new device)
6. When the reformatting is done, select Reboot from the Recovery Mode menu.
Jan 08, 2011 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
CREATIVE ZEN MP3 NOt gettin On
Have you tried using the reset button? try taking the battery off and just running it off the A/C charger.
Oct 25, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Proposed solution
Creative Jukebox 3
  1. Remove the battery cover
  2. Partially remove the battery
  3. Press and hold STOP button
  4. Slide the battery back into position - the unit should power on.
  5. When the CREATIVE logo appears on the display, release the STOP button then immediately press and release the PLAY button.
  6. The following options will appear on the display:
  • Clean Up (Performs a disk scan on the players hard disk)
  • Format All (Formats the players hard disk - Note: all contents will be lost)
  • Reload Firmware (Reloads the Operating System on the Jukebox. Note: Reloading your OS, will not effect the contents of the files stored on your Jukebox Zen. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install.)
  • Reboot (Reboots the device).
Aug 16, 2008 | Creative Labs Nomad Jukebox III MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Not rebuilding Library all the way
1. Press and hold the Play button while powering on your player.
2. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Oct 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Vision: M Won't Power Up
I had a similar problem with my Zen Vision: M. I had let it sit for awhile and the battery lost all power. It wouldn't charge or connect to the computer. After fighting with customer support for a long time they agreed to have it shipped in for service. I also was not able to find my receipt to send them. But I bought it at Circuit City and they are able to pull up any receipt for any purchase made with them. I suppose you could always try to try that with the retailer you purchased the device from. Before you go to all that trouble though try these steps: 1. Connect the device to the wall charger. 2. Hold the power switch to ON. 3. Put a paper clip into the reset hole. 4. Continue holding the power switch on until the Creative logo appears. 5. Select Format All from the Recovery Mode menu. (Note: THIS WILL ERASE ALL DATA FROM YOUR DEVICE! - but it's better than buying a new device) 6. When the reformatting is done, select Reboot from the Recovery Mode menu. Let me know what the results are from this.
Jul 27, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
19 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
