Question about Samsung HCN436W 43" Rear Projection Television
Samsung HCN436w 43in rptv
My tv is not switching on and is just staying on standby mode it makes the melody when u try to switch it on but then no picture comes on or sound what could be the problem and how do i fix it?
Try disconnecting the convergence board and see if it will turn on without this board connected - if it turns on then you likely needs to fix or replace the convergence board
Posted on Nov 30, 2008
HI MY SAMSUNG SP42Q2HD TV KEEPS GOING ON TO STANDBY EVERY 5 MINS IS THEIR ANYTHING I CAN DO TO FIX IT THATNKS
willnat126,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting procedure and help to isolate the problem and tells you where to get parts.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 09, 2011 | Samsung HCN436W 43" Rear Projection...
No power standby light
If it is the main fuse that is being smoked, there are a number of possibilities:
1) Since this is a CRT based set, the most common failure os of the horizontal output transistor. This goes shorted which causes too much current draw on the power supply and it pops hte fuse.
2) The switch mode power supply transistor has shorted.
3) Failure of the primary side capacitor.
Without seeing the set and taking some internal measurements, I can not state for sure the exact problem with your set. Since there are potentially dangerous high voltages present inside even when unplugged, I would suggest that you get a detailed repair estimate from a local service shop and post the results here. We may be able to walk you through the actual repair.
Dan
Feb 12, 2010 | Samsung HCN436W 43" Rear Projection...
When switching off the television with the on/off switch the red
That just lets you know that it is in standby mode..
Feb 01, 2009 | Samsung TXJ3678 36" TV
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
TV Switches itself back to standby mode continuously
if your remote is ok then this is due to power supply failure in your tv. either it is loose in oscillator ckt in switching section or it has failed. if not tech person call tech to fix it. not a major problem.
Oct 07, 2007 | Televison & Video
Can't get the phone out of vibrate mode
lol just hold the * key down bottom left
Oct 07, 2007 | Cell Phones
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Feb 20, 2007 | Samsung SlimFit TX-S2783 TV
Samsung HCN436W 43" Rear Projection Television Logo
89 people viewed this question
Henry  Thomas
Henry Thomas
