Question about IBM ThinkPad T30 2366 Notebook
T30 Raqm fix
Hi Harvester,
we have 2 T30s with the same problem... they both now work...
Thanks for the info...
We still have the T30 stop once in a while until we play with the RAM again..
You said that you had a fix for that... We would greatly appreciate it if you could help us out.
It seems like the RAM socket is intermitant when it heats up. Like the socket pins open when warm.
regards,
anmibou
Andre
anmibou@sympatico.ca
    Genius:
  • 2,028 Answers
Good.
Posted on Jun 24, 2008
My thinkpad t30 2366 has a lock sign in top left of screen.How can i unlock it?
Hi, If you are talking about the Boot, HDD, Bios password, then the only one way to recover it is to implement a chip on the systemboard to shorcut the protection or to contact Lenovo for a systemboard replacement. Otherwise you can check out theses 2 tutorials, with few skill you can make it yourself: -http://www.allservice.ro/forum/viewtopic.php?t=47&start=0 -http://marc.info/?l=full-disclosure&m=111234041830357&w=2 Unfortunalty, no other ways other round. Thanks and have a nice day J-
Jan 31, 2010 | IBM ThinkPad T30 2366 Notebook
T30 working with 1/2 memory RAM
WoW!, Ubuntu Lover.
Thums up for you Man, Live Free, Linux for Human Beings.
Regards,
Waqar.
Aug 06, 2009 | IBM ThinkPad T30 2366 Notebook
I don't know how to summarize this problem
Oh dear, this is bad. It is the motherboard. I have went through 4 t30s with a similar problem. It is on it's last legs, the only way to fix it is replace the mainboard (motherboard) (trust me i'm an I.T guy). Sorry to tell you that.
Nov 29, 2008 | IBM ThinkPad T30 2366 Notebook
Ibm t30 post beep error 1 3 3 1
T30's do have a well reported problem with their memory slots. It is possible to fix it if you are brave and moderatly competent with a low-power (15-20W) soldering iron with a good bit (I recommend a flat oblique tip of about 2-3mm, not a pointed one).
Firstly, heat the soldering iron and clean all traces of solder from the bit. You can use a wet solder sponge, or even damp kitchen paper. It is VITAL to remove all solder.
Remove power and battery from the T30. Open the memory cover, and remove all memory.
Taking great care, press the bit of the hot iron with moderate pressure (about twice what you would use to press a key with one finger) on each pin in turn for about 1 second, on the contacts of the memory slot that is not working. Because you have no solder on the tip, it does not matter that you touch more than one contact at a time, but there are very small surface mount capacitors between the sockets. Be careful not to touch and unsolder these.
There is a warning here. Do no wipe the iron across the contacts. Always lift the iron before pressing it on the next pin(s). If you do wipe iron across the contacts, you WILL bend and short them. These are surface mount components, and the wire contacts are easily disturbed and shorted. If you do short the contacts, it will be difficult or impossible to fix.
Remember there are pins on both sides of the memory socket. Do not worry if some of the plastic of the socket melts, it is not a problem.
Continue until you have worked on all of the pins. Patience is a virtue here. Allow to cool, re-assemble and test.
I cannot promise that this will fix your T30, but I have extended the life of 2 out of 3 T30s I worked on in this way. Note extended, because the design flaw will cause the problem again sometime in the future. The board appears to flex, which puts strain on the solder joints.
May 24, 2008 | IBM ThinkPad T30 2366 Notebook
Access to bios
you can use F10 while switching the system on. Alternatively you can also use Del key.
Feb 13, 2008 | Compaq EVO T30 Network Terminal
IBM T30 start up problems! need help
hi,
It's the memory slots. Trust me, I've seen this many times.
Do this.
Take memory out. re-install only 1 piece of known good memory in the slot closest to the rear of the laptop. Now, press on the memory slot itself, as if to push it into the motherboard, while turning the system on. If that doesn't work, try the other slot. I promise, this is the trouble 95% of the time. IF it works get back to me and we'll discuss how to repair it so you won't have to keep pressure on the memory slot.
Good luck
Jan 07, 2008 | IBM ThinkPad T30 2366 Notebook
Cannot hear music
The bad news is that your headphone jack is most likely shot. The soldered connections inside are most likely broken. This is not repairable generally, at least not for a cost that would be reasonable. Music will play through your computer because it can be read off your player through the USB connection. Use it as a data storage drive and buy a new one, or a used one. I've seen used T30s on Amazon for around $30 to $40.
Mar 26, 2007 | iRiver T30 MP3 Player
IBM ThinkPad T30 2366 Notebook Logo
49 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Michael Vincent Cruz
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
