Question about Hotpoint FFU00 Side by Side Refrigerator
Replacement ice maker
I am trying to replace my ice maker. The instructions say that I cannot use the new stripper, that I must replace it with the one on the old ice maker. I cannot seem to get it to fit. It is about 2 inches too long and does not fit into the slot. The model number for the refrigerator is csx22dme. The model number on the new ice maker is JS2
  • 525 Answers
Sounds like you may have gotten a wrong kit, or a mislabled kit. Take it back and ask the salesperson to correct the error. Ask them for some advice if they try to say it is the right one. They made a profit on the sale so they need to make it right with you.
If you get nowhere, which is likely to happen, post me back and I can help you come down legal on them.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 19, 2008
Ice make does not make ice.
You say water pressure is fine but are you saying that the water valve is working? That's one possible answer and the other is a bad ice maker.
Aug 03, 2015 | Refrigerators
Why is my Ice Maker in GE Refridgerator "leaking"?
We had this happen twice and both times it was the line that supplies the water to the ice maker. We had to change the line because it was made of plastic and had cracked.
Jun 05, 2017 | Refrigerators
Timer ice maker kenmore side
If the timer piece you are referring to is behind the square white cover, and it's moving slightly back and forth, you should visually check the ice making area it's self to see if the ejector fingers are jammed with ice, or against the ice stripper. Ice Maker jams can be caused by reduced water pressure to the unit mainly from the water filter, your water filter in the toe kick should be replaced at an interval of 6 months to a year, regardless of filter status light. When water pressure is low, not enough water fills the unit and the undersized cubes can become lodged or stuck in the ice maker while being ejected, equally so if there is an over fill situation caused by other failures the ice maker can't eject at all. Pleazer Appliance...
Ejector fingers
Ice Stripper
Apr 17, 2014 | Refrigerators
+auger in ice maker broken Can replace auger only? part?
Hello, Thank You for using FixYa. I will be helping you today.I checked every where and the ice stripper is no longer available for that ice-maker. You would have to replace the whole ice-maker.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | GE GSL25JFPBS Side by Side Refrigerator
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice stripper on my icemaker has warped. Its
when ice maker goes into harvest the unit stall on the ice /the heater comes on and when tray is warm the ice moves out on the stripper . . i would think the tray is loosing its coating and the ice does't release and the heater stayes on too long . may have to replace the mold or ice maker .. ****
Jan 18, 2010 | Refrigerators
Icemaker Ice Stripper Arm
just get a new im son quit n riggin the thing
Jun 15, 2008 | Whirlpool GD5SHAX Side by Side...
Ice maker.....one of the stationary fingers on the ice maker is broken. Can I just replace this Comb? or do I need to replace entire ice maker?
On some icemakers you can just get the stripper. It would depend on the brand and model of the unit.
Apr 18, 2008 | Refrigerators
Ice Maker- I am about to replace my 2nd Ice Maker
First Look at icemaker and see if fingers are sticking down in to mold with no water. Fingers should be slighlty above stripper plate (plastic piece mounted on ice maker that is closest to you)Also the fingers should rotate at all by hand. If its sticking down in the mold and the fingers move....it bad.
Then make sure the black rubber spout doesnt have ice inside (just squeeze it ......its rubber so you can feel if its iced up)
Yes, Whirlpool did have some issues with the Gears on the Motor module breaking also they have ice maker thermostat issues. I recommend a entire new updated In door Ice maker and you shouldnt have to worry about it again.
Jan 22, 2008 | Whirlpool GS5SHAXN Side by Side...
Kenmore side by side
Your motor module is bad on the ice maker. It is located on the left side when mounted in the refrigerator. It is under the White Cover over the end. It is brown in color. To verify the correct problem, the ice stripper arm in the ice maker that turns and pushes the ice out of the mold, should be pointing up towards you when it is in the mounted in the refrigerator. I call it the 2 O'clock position. If the ice stripper arm is pointing another direction, it is broken. I sell the module on Ebay as username, themackshack. My parts are genuine factory parts. Good luck!, Mack
Jan 08, 2008 | Kenmore 50522 / 50524 Side by Side...
Hotpoint FFU00 Side by Side Refrigerator Logo
125 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
