Question about Bose Lifestyle 28 System
DVD does not eject
The posted solution does not work. How can I get the DVD out?
  • 97 Answers
Try unplugging the system for a couple minutes and then after plugging back in try ejecting.
Posted on Jun 19, 2008
Cd wont eject out of t_v
Disc loading mechanism fault. Contact any service technician. The mechanism should take out from the TV; either for repair, or replacement. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Televison & Video
Tip
I took the dvd player out and did what you posted. The dvd player still won't...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Oct 19, 2008 | Samsung DVD-V4600 DVD Player/VCR
Eclipse AVN5504D radio only displays eject cd, eject dvd, open. What is the solution, I dont have the eclipse disc.
plorer Stereo Problem - Ford Forum - Enthusiast Forums for Ford ...
www.fordforum.com > ... > General Ford Forums > General Tech
Nov 5, 2011 - The Eclipse AVN5504D stereo only displays eject cd, eject dvd, open. plus some asian writing at the top which I don't understand sorry.
Japanese navigation toyota,eclipse insert map disk solution ...
www.pakwheels.com > ... > In-Car Entertainment (ICE)
Oct 9, 2012 - 21 posts - ‎16 authors
Despite the radio having all the instructions in Japanese, it has been ... The Eclipse AVN5504D stereo only displays eject cd, eject dvd, eject ... More results from www.pakwheels.com
- avis des utilisateurs [ tradecarview ]
Jun 23, 2011 | Car Audio & Video
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Dvd will not eject when using eject button.
I am going to sandbag it. I can use that particular cd to workout with. I will just attach a dvd player separate since most postings can't use the dvd anyway after they get the cd out. Thanks for the help anyway! Susan
May 27, 2009 | Mintek LCD TV Progressive Scan DVD Player
Dell xps m1330 dvd won't eject
Does windows pick up the drive? If so right clcik the drive and select eject. Apart from that if theres no pin hole you could try re-installing drivers. Go to device mangaer and right click the dvd drive select uninstall then reboot let it re-install itself and try ejecting again. If the normal button doesnt work though it may be a physical issue.
Let me know how it goes.
Mar 23, 2009 | Dell XPS M1530 Notebook
Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Jan 02, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
DVD Stuck inTV/DVD combo unit
Same here.  Had the TV for about 6 months and had a DVD get stuck for the second time.  Used the same method of unplugging and plugging back in.  Then hitting the Stop/Eject on the side and it came out.  When plugging it back in I could hear the DVD "engage".
Jun 06, 2008 | Westinghouse SK-32H590D Television
Won't eject
Had same problem as you, never will I "hit" a machine but read a post to do so. I tapped on top as I hit eject and it worked. Something about a magnetic effect as the thing ages and a solution to use electric tape. I will just tap, only as nessesary. My computer did the same (can't tap) I tried to always have a disc in drive which made it eject easier. Hope it works.
May 14, 2008 | iLO DVDR05 DVD Recorder
Trouble Ejecting Disks
Turn your laptop upside down. Whilst it's upside down, press the eject button!!!!
Oct 07, 2007 | Apple MacBook PC Notebook
Bose Lifestyle 28 System Logo
87 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
