Question about Sharp Office Equipment & Supplies
I don't know how to remove and install toner for my sharp ar-337
If you go here:
http://www.sharpusa.com/files/cop_man_ar287_337_407.pdf
You can download the operation manual for that machine, on page 4-5 they explain how to replace the toner and have pictures showing how.
here is the text on how to replace.
Adding Toner
1 Open the front cover.
2 Pull down the toner hopper lock lever and pull the toner
hopper out slowly until it stops.
3 Tap on the top of the toner cartridge 5 times. Hold the
new toner cartridge vertically and vigorously shake it
up and down about 20 times, then invert the cartridge
and again shake it up and down about 20 times. This will
loosen the toner and allow it to flow more easily into the
toner hopper.
4 Place the new toner cartridge with the tabs in the
notches as shown.
5 Slide the toner cartridge along the guides over the toner
hopper.
6 Hold the toner cartridge with one hand while pulling on
the sealing tape to remove it.
7 Tap on the top of the toner cartridge 5 times to start the
flow of toner into the toner hopper.
l If the toner cartridge was sufficiently shaken as described in step
3, it will take about 50 seconds for the cartridge to empty. Do not
remove the cartridge until it is empty. If not empty, tap on the top
of the cartridge again until empty.
8 Slide the empty toner cartridge back along the guides
and remove it.
l The cartridge opening will be closed as it is moved back along
the guides.
9 Slide the toner hopper into the copier and return the
toner hopper lock lever into place.
10 Close the front cover.
NOTE:
Add only one cartridge of toner.
Posted on Jun 19, 2008
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
Apr 06, 2014 | Sharp AR-M237 Copier
Sharp ar-337 driver windows 7
This machine is to old. Sharp does not support drivers for these anymore. Try using an HP driver and configure the port to the IP address of the Sharp 337. You will not have any finisher functions, but you should be able to print.
Jul 22, 2012 | Sharp Office Equipment & Supplies
Sharp ar 5520 fault code f2subcode 40
F2 40 = ATC sensor abnormality
Check e remedy :
Remove/Install the toner cartridge again.
Replace the toner cartridge with a normal one.
Sep 06, 2010 | Sharp AR-5320 Black and White Copier
Developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Apr 30, 2010 | Sharp SF 2020 Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
How i can install developer in sharp copier AR-5316
The steps to take are
  1. Open the toner door.
  2. Remove the toner cartridge.
  3. Unscrew and pull out the compartment housing the toner cartridge.
  4. View to see three screws on the compartment undo them.
  5. Next you see an enclosure with spiral, rigth there you pour in your developer. Then couple.
I hope it worked.
Thanks
Engr. Kachi.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Problem with Sharp AR 337
are you refilling the toner cart? if yes..
An easier way is to take out the whole developer unit. Pull down green handle as if you were replacing the toner, there is to the lower right of the developer unit a white handle that if you move to the right will allow you to remove the DV unit. Then there are 5 or 6 screws around the top edge that will allow you to remove the top and manually refill it there instead of trying to refill the cart and making a bigger mess.
Hope that helps...
Jun 20, 2008 | Sharp AR-M237 Copier
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
231 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
