Question about Refrigerators
Hot door frame ( Whirlpool side by side door frig )
The front frame of my side by side is hot where the door magnet touch, we cleaned dust from under and back and its less hot but still warm, the fan at the bottom right rear is not working.
  • geealex Jul 01, 2008
    My problem is exactly the same. I took off the cardboard insulation panel at the back, cleaned out the dust, and then plugged it in again. The fan doesn't work that faces the freon container (?). The container is extremely hot. I don't know if it's the fan, a circuit, or the wiring.
    How dangerous is it to let it run until I can repair it?
    The product is about 10 years old. Model number is ED25PQ, side by side refrigerator.
  • 525 Answers
The mullion frame stays warm to eliminate sweating during the heat season. This is accomplished by routing the heat removed from the unit by the freon through tubing behind the mullion strip(s). Generally this is experienced as "warm". However, if the unit runs longer than normal in an attempt to pull heat out of the box to satisfy the cold control, these mullions will be HOT to the touch. Basically this serves as an alarm to alert you to a circulation problem. You describe a fan at the bottom right rear as "not working"?
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 19, 2008
I have a ge refig side by side the # is 62D581P016 the door frame where the gaskets are located gets hot to the touch. We have cleaned the back under the frig and the fan is running, however, it is st
Most modern refrigerators have heaters around the gasket to keep frost and condensation from forming. What you're seeing may be normal.
Sep 09, 2014 | Refrigerators
Exterior panel between freezer and refridgerator that magnetic strip sticks to is very hot.
Have seen it many times before especially on Whirlpool fridges before. It is not detrimental to the running of the fridge but has the tendency to warp the door fridge seals. In my opinion, when the fridge was piped up, instead of running the high side (hot pipe from the compressor), through the radiator first and then to the fridge body, they have done it in the opposite way. As a result, All the heat from the compressor is going firstly into the fridge frame to eventually exiting and then going to the radiator.(Thats why it is so hot between the doors). To rectify this, you need a technician to swap the pipes over at the back as already discussed, then regass..
Aug 28, 2010 | Whirlpool Refrigerators
Getting hot
This can be caused by the condenser running hot due to being dirty or the fan not running. See the link below for details on how to clean and check this.
Hot Rail between Freezer and Frig
May 31, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Frigidaire #FRS24XHA is hot to touch and freezes food on the left
Hi: Those areas are designed to be warm to keep moisture from forming there(Moulion coil). When they get hot it means the fridge is over working. The condenser coils remove the heat from the fridge. When clogged the heat will leave anywhere it can. The moulion coil is the strip you described,and will overheat when the condenser coils wont disperse the heat. Most likely the coils need a good cleaning, on the bottom of the ref. Use a coil brush and a vacuum. Or even an air compressor to blow the dust and hair out; plan on dusting the house too. Pull the grill off the front and clean them. If real bad pull the panel of the lower back and clean it out too. Since you work in detroit the dust and hair on the coils would be like putting a blanket over your radiator. Parts would heat up. I hope it's just the coils. If a compressor is failing you can get the same symptoms. I hope it is the latter for you, as I'm in your boat also. I hope this helps, Jeff
Jun 09, 2009 | Frigidaire Refrigerators
Bar bewteen frig and frezer is very hot to the touch.
Yes that is normal. It prevents moisture from building up.
Apr 04, 2009 | Whirlpool GS5SHAXN Side by Side...
I have a side beside whirlpool refrigerator/freezer. today I noticed the strip between the frig and freezer was very hot and coil under frig are almost too hot to touch. It has been this way since about...
no danger of fire, they(Whirlpool) run a copper heat tube through the center mullion of frig, to cut down on amount of undesirable condensation that may build up between doors, reason for extra heat can be from leaving door open too long, perhaps the coils under the frig need to be vacuumed,
Oct 12, 2008 | Whirlpool Refrigerators
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Door frame really hot to touch
Also clean the coils underneath the unit as far as the fan (condenser ) you can put a house fan on the back blowing to cool the compresser until you get a replacement. That fan runs anytime the compresser runs
Jun 06, 2008 | Frigidaire FRS26R4A Side by Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Loud Humming and Hot Front Panel
DONT TOUCH ANYTHING. IF IT IS COOLING CORRECTLY LEAVE IT. LOUD HUMMING IS COMMON ON SOME COMPRESSORS.(ANNOYING I KNOW).THE HEATING ON THE FRONT IS NORMAL AS IT IS THE MULLON HEATERS WHICH RUN THROUGH THE FRAME. IF THAT AREA WERE COLD, CONDENSATION WOULD OCCUR AND WOULD DRIP CONTINUOUSLY.
May 31, 2007 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
