Toshiba DVR670 Player Logo
Posted on Nov 16, 2010
Just purchased Toshiba DVR670 and hooked it up. Cannot get a setup menu to appear on the TV screen. All cords/connections appear to be working as the picture has improved and it runs beautifully through the stereo. Have read manual and cannot find a place that addresses this. This is so basic and I've NEVER had problem with this before. Joyce Lamoine, Maine
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
180
Points
Did you put the t.v. on the correct input select.
We have one dvd that uses video 3 and another set that
uses video 5.....
AND.. there is a set up menu on the remote
hope this helps.....we just bought one of these and
used this site to get help with our volume. Great site for
help....so if my suggestions don't work, then maybe
someone else help will
On my toshiba 52hm84 how do I hook up a digital converter box
how to hook up on toshiba 52hm84 digital converter box
Connect antenna to antenna input on converter box.
Connect RCA audio/video cable from output on converter box to audio/video input on TV.
Plug the converter box's AC power cord into an electrical outlet.
Turn on TV and select "line" or "A/V" input.
Follow setup instructions in converter box owner's manual.
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
3helpful
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
1helpful
2answers
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
1helpful
3helpful
2answers
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
No picture on my television
Found this on the www.toshiba.com website. Q. I have sound and no picture with the TV powered on?
Models: 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL67, 42HL167, 47HL167,
52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00111
Using the buttons on the TV itself (not the remote control), press the “MENU” button to see if the TV’s MENU appears on
the screen. If the MENU does appear on the screen, verify that all of your video connections are secure on the TV and on
the connected device. Double check that you are connected in the appropriate jacks, check the other inputs of the TV to
see if the video appears on any other input. If you still do not see any video but can access the menu, try to reset the TV
to the factory defaults.
1. To reset all settings to default values:
i. Press the “MENU” button on your remote to open the menu.
ii. From the SETUP menu, highlight INSTALLATION and press “ENTER”. A new set of Installation
iii. Open the SYSTEM STATUS menu, highlight SYSTEM INFORMATION and press “ENTER”.
iv. Press the LEFT or RIGHT arrow to scroll through the menu bar to select FACTORY DEFAULTS.
v. Enter your PIN code (or 0000 if no PIN code has been set).
vi. Highlight YES and press “ENTER”. The TV will turn off automatically after a few seconds. After the
vii. If the MENU does not appear on the screen, try resetting the TV by unplugging the power cord for at
least 3 minutes.
viii. If neither of the above steps resolved your problem, you can get assistance with this problem by
contacting our customer solutions department at 1-800-361-3811 Monday through Friday 8am -7pm
CST I hope this helps you with your problem.
Input Selects
well you have to put them in y w r and then turn the tv on and make sure all the cords are in tight
2answers
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
2answers
Hooking up dvd player
Your cables are coded red(right audio), white(left audio) and yellow(video). The cable inputs on the dvd player and tv are likewise coded. Just connect color to like color. In setup, do not
change NTSC! If you should go to PAL you'll never get out of setup and all you'll have is screen roll, as though the vertical hold gave out.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
