You need to have the OS CD to do that. More often than not once the CD is inserted the installation process should in case it doesn't start then you need to change the Boot Sequence and the complete step is mentioned below. Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive. At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu http://support.microsoft.com/default.aspx/kb/918884 http://www.winsupersite.com/showcase/winvista_install_03.asp Windows Vista Installation Super Guide After installation >Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them. Save all Data, as it will be lost during a clean install.
Its Simple you are sure to like it.....Try it Out....Good luck
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
