Question about Sony KP-51HW40 51" Rear Projection Television
Power problem before the cannons on a rear projection TV
Arcing of power at a three point distributor
  • Sony Master
  • 8,617 Answers
Can you post a picture of the part youre referring to or can you give me the board location number of the part in question and I should be able to help you out with your problem.
Posted on Jun 23, 2008
I have a Phillips Rear Projection TV and when it is turned on, it has a hiss coming from the back. Is this dangerous? Is there a way to fix it?
The flyback transformer is most likley arcing. It is high voltage so eventually the set will shut down and not power up again untill the transformer is replaced. However those flybacks for that model are very hard to find.
Sep 29, 2010 | Philips Magnavox 55P9271 55" Rear...
My TV was snapping or arcing then no picture at
Sorry to hear this. What has happened is that CRT coolant has leaked from one or more CRT's down onto the Main bd and or the Power Supply bds and shorted them. You must replaced ALL three CRT's and the shorted Main bd and or the Power Supply boards. Then a Full Convergence Alignment must be done by a very good and experienced tech. Not cheap.
Apr 04, 2010 | Samsung PCL545R 54" Rear Projection...
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
No video, No sound, TV pops when you turn it on!?
you have high voltage arcing taking place ,poss tubes or flyback,splitter assy,focus block, you must try to pin point where or by what the arcing is taking place,safety first. unplug the unit and inspect for black burn spots on or near metal parts.
Oct 07, 2007 | Panasonic PT-51HX41 51" Rear Projection...
No picture
sounds like high voltage arcing,/flyback,focus block,h.v. anode lead etc.
Sep 07, 2007 | Toshiba 55H70 55" Rear Projection...
Arcing inside no picture
Most times arcing like this is from the Horiz. output transformer (flyback). The insulation has a break down and up to 30 KV will find the nearest path to ground. This would require a tech. to repair the unit. This repair will most likely cost around 250.00.
May 09, 2007 | Sony KP-51WS510 51" Rear Projection...
TV Turned off, now there is a clicking noise when plugged in.
had a 51" GE rear projection donated to myself. While off and power button pressed there was a clicking noise from the front of the unit. Rear cover was removed and it could be observed that the hv splitter had a crack in the casing and the power was arcing out of the splitter. I purchased a $72 dollar hv splitter, i read that the $20-$30 dollar one would break within a year, and the unit powered up no problems.
Nov 20, 2005 | GE 46GW947 46" Rear Projection Television
Sony KP-51HW40 51" Rear Projection Television Logo
24 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
