This not that simple Your tortion bars are must have some distortion at this point being a 2000 you will need to estamate some what but it can be done To tighen the tention you adjust the anchor arm bolts at the rear of the bar one on each side you also need a mesurment in the front take some string and strech it tight across the front end wheel to wheel at the bottom of the ball joints for your referance point the lower joint The vehicle should be on flat level ground Tighten the anchor arm bolts one at a time measure the distance from the top of the thearded end of the adjuster bolt to thepoint where it rides on the adjusted bracket then measure the distanct from the center of the bar front to the string when this distance is vary close the suspension should work fine Rember you may have to tighten one bar more then the other to get this but have to take into account bar distorition from years of use good luck
SOURCE: Nissan Frontier torsion bar replacement
well it depends how you want to adjust it, if you want to lower it, back out the screw on the torsion key a couple of turns. raise, screw it in a couple of turns
SOURCE: want to change torsion bar keys
The torsion keys are supposed to give 2-3" additional drop vs.the "free" method. I know adjusting the torsion bars kills the ride but how bad is it and how far can you go???
Believe, 15/16 socket would be the correct size. Also, be aware that they are probably pretty rusted and VERY hard to turn at first. Air tools do no good, so you'll need a 1/2" drive breaker bar and a long pole to put on the end. This is the fastest way to get the torque you need to break those suckers loose.
I suggest measure and writing down the height about 3-5 spots on each side, whether it be the frame, body, or whatever. Crank each side a few FULL thread turns, then measure again. Once you get about the height you want, measure both side to make sure they're equal. After that, it's best to get a full alignment as some of the suspension will now be at different angles (of course).
SOURCE: 95 explorer lower control arm replace
No the torsion bar if you look at it where it goes to the under carriage it will have a bolt for tension on each side. Are you tring to replace the bushings for the torsion bar? If so answer back.
SOURCE: Adjusting torsion bars landcruiser 100 series
when you get a front end alignment that adjustment is made for you also. Do not attempt to do it for you will not get the adjustments correctly done without the specifications that are needed
SOURCE: how to adjust a torsion bar
Step 1
Jack up the vehicle on the wheel to be adjusted, and set the frame rail onto a jack stand. This is to release the stress on the torsion bar so it can be adjusted easily.
http://www.readylift.com/t-torsion_bar_keys.aspx
