Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson stylus dx 7450 printer
I've renewed with compatible ink cartridges ok for first time. but second change of just black catridge (& new to me cartridge carriers for each colou)r . printer will not acknowledge/print. says buy new cartridges. any suggestions?
    Novelist:
    Scholar:
  • 125 Answers
You have a wide format printer but it has the same basic principle as the desktops. You can buy remanufactured cartridges which were reset for you. Or you can refill them. If you refill them, you need a resetter because Epson cartridges have a chip on them which needs to be reset. Because when they are empty, the printer will recognize it as empty and will not function till you put in a new cartridge. If you bought a remanufactured cartridge, and your printer won't recognize it, you need to go back to who sold you the cartridge and either have them reset it or give you a replacement.
Posted on Aug 01, 2008
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    Jun 10, 2011 | Epson Stylus NX400 InkJet Printer
    I have an epson stylus SX600FW printer. i have used the compatible ink cartridges for months. just lately the black ink cartridge is not working when you want to print out and you have black and coloued...
    The black catridge is depeleted. Some cartridges have a chip which is resetted after power up so you won't know how much ink is left.
    On the other hand never mix orij. and compat. carts together.
    pls. vote for better service... Thank you
    Nov 13, 2010 | Office Equipment & Supplies
    I just change my ink printer and the printer
    to reset your printer, turn off your printer, remove cables on it, press and hold the power button for 5 seconds. Reinsert cables then turn on your printer. Hope it works...
    Jun 02, 2010 | Epson Stylus NX400 InkJet Printer
    Epson Stylus dx 7450
    It sounds like a driver issue. Have you checked that bothcomputers have the correct driver for your printer?
    Mar 18, 2017 | Epson Stylus Multifunction Inkjet Printer/...
    Epson stylus DX 7450 doesn't print black
    Hello, This can be FIXED. I'm not trying to be helpful. I'm here to FIX your problem.
    You want to make changes to the printer settings to once again print in Black and White or Grayscale mode by going to Start Menu, Control Panel, Printers. Right click your printer and select Properties. Now make the changes to everything prints Black and White or Grayscale. This will make the change effective system wide as opposed to what you did which was for a single print job in a program.
    Now, unfortunately, you will still get an error message that your color cartridges are empty anyway because they are.
    To disable the error message do this.
    Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
    This will disable the empty cartridge error on most Epson printers.
    Let me know of your results as I am here to FIX your problem. I'm not here to be helpful. I will work with you until this is FIXED or is now FIXED. OK? Use the comment box below to let me know your results.
    Regards,
    Worldvet
    Oct 12, 2008 | Epson Stylus DX6050 All-In-One InkJet...
    Ink problems
    1. First make sure you have installed the catridge correctly by taking out and placing it again.
    2. Then,
    The following Epson ink cartridges should be used in your device:
    Black: T0431 (high capacity cartridge)
    or T0441 (standard capacity cartridge)
    And make sure you use the genuine original EPSON catridge.
    3. If you are using a genuine one, then TRY TURNING OFF YOUR PRINTER AND SWITCH IT ON AGAIN.
    If you do not suceed then,
    Please contact Epson to resolve this problem with a technical support representative.
    U.S.: (562) 276-4382
    6 A.M.-6 P.M., Monday-Friday
    (Pacific Time) Canada: (905) 709-3839
    (Pacific Time)
    Before you call, be near your computer and printer and have ready your product name, serial number and proof of purchase information.
    Hope my info solves your problem,
    Let me know you want any more ideas......
    Oct 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
    Installed compatable cartridge for epson dx 7450 printer rejecting non epsom cartridges
    I have an Epson dx 7450 scanner printer that will not accept non epson so called compatibles .Anyone found a solution ? I've tried a number of manufactuers and they all don't work . I really don't want to fork out for epson inks ?
    Sep 30, 2008 | Office Equipment & Supplies
    EPSON PRINTERS how to replace inks in epson DX 7450
    You must surely have sorted this one out by now Doris! However, if you haven't, how to change print cartridges on a DX7450 is very clearly explained in the user handbook (on the CD that came with your printer). Insert the CD and select "Custom Install" then "Users Guide". Once its installed, double click the new Epson Icon on your screen and selct "Printing" then "Replacing Ink Cartridges". If you don't have a CD, download the User's Guide from the Epson website at http://www.epson.com - just choose your locale, then select Get Drivers and Support - Printers.
    Jun 13, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
    Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
    630 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
