Code error on my copier
When I turn the copier on, the copier started flashing E7 by the moment it should be ready to copy.The start button flashes.That is ,it is not stable because of the E7.How can I fix this problem?
  • 1 more comment
  • Nike Merritt May 11, 2010
    It should flash another number after the E7 so the code would be E7-01. E710 and above is the ADF lower numbers are sorter problems. If you reply with code I can give more info
  • Timothy Van Der Heyden May 11, 2010
    make and model?
  • TRANSCORP99 May 11, 2010
    WHAT KIND OF COPIER?
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
WHAT DO IF I HAVE AN ERROR CODE E7-03 ON MY SHARP PRINTER MODEL NO ARM620N
The code refers to a hard drive issue. This could be caused by a corrupted file or there is an issue with drive itself. First thing to try is to reset the error code. This sometimes works & the machine runs fine after. If the code returns then you could be looking at a new hard drive.
To reset the machine, make sure the copier is in COPY mode, then press the following 4 keys in sequence #*C*
The machine should now be in simulation mode. Enter 14 then press the copy start key. Press the copy start again then press the CA key. The machine should reboot & if the drive is ok the machine should be ready to copy. If the code reappears the its most likely the hard drive is faulty.
Dec 27, 2014 | Sharp Office Equipment & Supplies
Error code e7-11 comes up on my sharp mx-m260 e7-11
An E7-11 is an
Improper CCD white reference plate
reading level for copy lamp lighting
You can try taking the glass off and cleaning the white strip under the **** glass, the mirrors and the lamp. If that doesn't work it could be the flat cable coming loose of the scanner or the CCD going bad.
Oct 18, 2011 | Sharp MX-2300N Color Copier
Hi my copier displays E7
Check this out :
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the **** glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
My error message is E 7 flashing. After leaving it off over night it worked for a couple of copies. Now I am getting the same error message E7.
press and hold the copy key the second part of the code will show then go to google and type in "sharp ar-m205 E7-xx"
where xx is the last of the code you should get an answer there
Jan 12, 2010 | Sharp AR-M205 Copier
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Xerox XC1020 Flashes code H 4
This should resolve your issue. If not it would most likely need a heat rod. But there ia probably a 99 percent chance this will cure it. Let me know please.
  9. Run a test copy.
Feb 16, 2009 | Xerox Office Equipment & Supplies
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
E 7 sub code 20
the error code is E 7 - 02 cant find solution, help
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
E7 problem
E7-02: LSU trouble
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
"1" key, "4"key
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
156 people viewed this question
k24674
jasbo
jasbo
