Question about Starbucks Coffee Makers & Espresso Machines
Takes a long time to steam milk. water comes out of the brewing head while steaming milk
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 99 Answers
I'll preface this by saying i have never used a strarbux machine, but I have used dozens of others (daily habit for 18 years now)
when are you trying to get your steam (ie before or after brewing the espresso)
If you have been trying before, wait till after (if your machine does not let you turn off the espresso output then when the coffee starts to slow down (just past the peak of flow).
It should take only a few seconds to steam the milk. (also the closer to the surface of the milk that the steam is released the frothier the milk will get)
Posted on Nov 16, 2010
SOURCE:
My caffitaly S 23 does not dispense hot Millikan after the coffee has dispensed. Just hot steam and a little bubbly hot water. I have cleaned it it and will dispense milk and the next cup doesn't.
First; I am NOT a Caffitaly repairman. Though I have worked on mini espresso machines. Sputtering and/or poor steam is an indication that your brewer is not up to brewing temperature.
** Most of these home machines have a very small boiler or tank. They are designed to produce hot water and sometimes steam to brew a small 'European' espresso. Here in the USA we like our coffee weaker and with lots of 'other' things mixed in. The 'Americano' is the same amount of coffee but with a lot of hot water added. This amount will tax the small boiler to it's limits. Top it off with a grande latte would be probably be beyond it's ability to completely froth/heat this amount of milk. When you order a Latte from a Barista you will note that it takes a while to froth a Pitcher of cold milk. They are using a large espresso machine and probably pulling a double shot of espresso. To make a similar drink with any home machine requires doing everything 'double' or twice brew. (3 times?) You will need to check the 'ready' light to make sure the brewer is up to heat prior to brewing your next cup.
** Suggest brewing a regular size or 1/2 a mug of coffee-latte then come back again later for another fresh hot cup.
Aloha! ukeboy57
Dec 21, 2017 | Coffee Makers & Espresso Machines
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
My maxim steam coffee machine will boil the water and froth the milk, but for some reason will no longer allow water to feed through to make the expresso - any ideas?
First things first, try a descaling solution, especially if you live where there's hard water. Sometimes minerals can crust up the brewing portion of the internal tubing. The steam part still works because it essentially leaves the limescal in the pot, channeling only steam through the steaming wand. Dump out any water in the reservoir, then put in a mix of half filtered or distilled water, and white vinegar. Run it through, setting the switch for brew mode only. Once you see it coming out of the filter holder, turn the machine off. Let sit for an hour or two, then run the same sequence again, shutting it off the moment you see the water/vineger mix coming out. Once again, let sit a while, then on the third cycle, let it run all of the vinegar solution through. Let cool, and rinse the reservoir with water, (put in water, swirl the machine around, then upend it to dump the water out.) then run the full reservoir of distilled wather through, repeating if necessary, to clear out the vinegar.
If that doesn't work, or if the vinegar solution never comes through, not even in a trickle, then there are other issues. Here's how to troubleshoot them.
The next steps will need to be done with some caution, as it may splash or shoot steam and/or boiling water out from the side of the porta filter holder!
Step 1...Remove the filter, and run it without coffee or filter in it. Do this from a few feet away or with something between you and the brew head of the machine, as it may cause hot water to spray with a fair amount of force!
Does the water come through the filter holder? If it does..
Step 2. Run it with the empty filter. If it the water doesn't come through with filter in place, then your filter is clogged, and you'll need to take a pin and clear the holes in it. If it does, then you're grinding your coffee too finely, or tamping it down to hard.
If the water doesn't come through with just the empty filter holder, then you've most likely got a valve (A.k.a. Brew/steam switch) problem. Frankly, it's easier to buy a new machine than replace that valve, especially if it's the automatic variety that switches you to steam whenever it's finished it's brew cycle.
If you've got one with the manual brew/steam switch valves, you can pull the knob off and see if it the stem turns with a needle nose pliers...{{NOTE: DO NOT DO THIS IF THERE IS STEAM LEAKING AROUND THE KNOB! Steam leaking around this knob can indicate that the ceramic valve is compromised, and could cause live steam to shoot out of the place where the knob is!}} if it does turn as smoothly as usual, and the machine works, then you just need to repair the knob because it's gotten stripped out or is broken where it meets the valve stem.
Nov 08, 2017 | Coffee Makers & Espresso Machines
Gaggia titanium. The water and steam are all going through the brew head instead of coming out the wand when I need it to. I have cleaned everything, used a pin to clean the wand (it didn't need it) ONE...
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
Cant steam milk and brew expresso at the same time.
You are not doing anything wrong.. that's the way this uint works.
Jan 14, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Steam from brew head, but no water
  1. If you take the coffee filter and head it in light, can you see a little hole in the middle? if not, try to clean it else you have to replace it.
  2. Can you brew out water without the filter holder in the machine? If not, loosen the screw in the middle on the machine where the filterholder shall be and take of the filter. Clean the filter and put it on the machine again.
Hope this help you
Jun 10, 2008 | Breville ESP8XL Espresso Machine
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
141 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Pierre Laplante
Info2011
Level 1 Expert
Steve Allison
Steve Allison
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
