posted by massimo001 on Jun 19, 2008
Hi i have an Soundstream STC 80 tape deck and i mistakingly crossed the Earth and the power!!!
how can get this unit repaired? what is the likely fault?
i Use the da vinci as a valid product as it wont accept the STC - 80
Best Solution
posted on Jun 19, 2008
If it was properly fused, the fuse should have blown without causing any other damage. If it was not properly fused, it probably caused the reverse protection diode to short and burned a trace on the circuit board.
Any competent repair shop should be able to repair it unless the reverse protection diode opened instead of shorted. If it opened, the damage could be much more severe.
Rating Locked! (?) massimo001 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Soundstream Davinici Car Audio
Email this problem
Email this problem
Can you Help with these Car Amplifiers problems?
Repair Service
Find Car Amplifier Repairman Near You:
