Question about Microsoft Windows Vista Ultimate Edition
Hard Disk Failure
What are the reasons for a Hard Disk Failure? How can I save my hard disk from failing? I have Hard Disk Drive Inspector installed. I alerts me that:
The temperature of the hard disk is 49 Deg.
My hard disk is going to fail on 23/6/2008.
I hear a sparkling sort of noise from my computer speakers.
My CPU Fan is very noisy.
    Novelist:
    Scholar:
  • 70 Answers
Replace your fan. The fan is most likely cause of noise in speakers and can cause premature failure of your hard drive. Drive inspector takes into account the 49C reading when predicting failure. Your fan can be replaced inexpensively, even if you have to replace your whole power supply. Typically this is just a plug-in. Anyone can do it.
While pagebor is correct, "...it will fail one day.", it doesn't have to be the 23rd and could easily last many years. Often, most drives fail from non-use. I leave mine on 24hrs a day and have not had a failure in 15 years. Oh, by the way, I've replaced the fans in these systems about 3 times in that same period.
Posted on Jun 19, 2008
    Genius:
  • 2,785 Answers
As the hard drive have movable parts it will fail one day.
If you defragement your hard drive monthly then it will take good care of your hard drive.
As the inspector is saying you should be ready for failure of your hard drive and you should back up your data.
My lappy hard disk is giving status that hard disk failure try to install in other location. then i connected it to my pc to take backup
Not sure I understand your Question... or maybe you are making a statement? But, it sounds like your hard drive (HD) is dead, no good , non useable... So what are your options? Purchase another hard drive, you should have received system backup disk or install disk with your laptop , you can use them to reinstall the operating system (OS) Windows on the new hard drive. There is a slight possibility you could try them (the install disk) to re-install your OS on your original HD, but again it sounds like your HD is dead.
If you have never made a back up of you hard Drive, then all your data (pic, documents, game, contacts) are lost. The problem most people don't understand is if the hard drive crashes for physical reasons, the spring breaks inside, or a diode burns out, then the data on the disk are lost.
You may also take your laptop to a computer repair shop near you and they can tell you more about your options.
Jun 25, 2015 | Hard Computers & Internet
How do I fix a failing hard drive?
First and foremost backup your data if possible. Then if you have bad sectors on the hard drive you might try and run hdd regen. it is free and can get it from HIRAN'S BOOT CD 15.2. IT HAS SAVED MY TAIL MANY TIMES OVER.
Jun 14, 2015 | Cybertron Computers & Internet
I have an ACER Aspire 5542 laptop and when I switch on I get the following message. "SMART Failure Predicted on Hard Disk 4 WARNING: Immediately back up your data and replace your hard disk drive....
Save your data asap and replace the drive it's failing. All drives fail over time you are lucky in that you are getting a notice. Others are not as fortunate.
Aug 30, 2011 | Western Digital (WD6400BEVT) 640 GB SATA...
Hi, For a week or two now when i put my Sony Vaio on i get a message saying my hard disk is failing & to back up my files but when i put a disk in it fails to back up. It's also telling me the name...
You need to purchase a new hard drive and have it installed, If you have anything important on your laptop right now, that is what you want to create a backup of, or you can have the store you buy the hard drive from do the back up for you and most computer stores will load it all to the new drive for free
Aug 22, 2011 | Computers & Internet
My hard disk on nx9420 failed (i get the message 'critical error - imminent hard disk failure, save all your data'; but the computer will not boot (just says press 'control alt delete')....
This warningmeans the hard disk will fail sometime in the near future. You need to back upyour data regularly before the hard disk fails or you will lose your data.
When the hard disk fails, you need to replace with a new one and installWindows on the new hard drive to get your computer working again.
If you cannot boot up your computer then -
Remove the hard driveand connect it to an USB hard drive adapter and plug it into a workingcomputer's USB port. If this computer detects it as an external storage deviceand you can open the various folders and files then back up your data.
If not you are in trouble, there are companies that can recover data fromfaulty hard drives BUT it will cost you an arm and a leg for their services.
Jul 18, 2011 | Computers & Internet
I have samsung's hard disk it making noise like chuk,chuk.. and after that machine get hanged. hard disk is old but it has so much empty space. how i can fix this problem, please give me solution for...
Hi princewild99,
The reason why it's making noise is the hard disk is failing. Hard disks are composed of mechanical parts and is prone to wear and tear. I greatly recommend that you get another hard disk instead. There's no way to fix it unfortunately and you don't want to lose any files saved if you continue using it.
Hope this helps.
Feb 24, 2011 | Computers & Internet
MODEL IS VAOI VGN-NR21M_S HARD DRIVE FAIL, CANT INSTALL NEW OPERATING SYSTEM ON NEW DRIVE AS WINDOWS NOT PICKING UP NEW HARD DRIVE, IN BIOS THER IS NO OPTION TO SET IT TO AUTO DETECT, HELP!!
Hi !
For some reason, some hard disk will be damage due to bad sector and you cannot do anything about it not reinstall any operating system.
If the Hard Disk Drive failed to install the operating system, the hard drive is damaged and cannot be reformat. The only solution is to replace new Hard disk drive to install the operating system.
Jan 07, 2011 | Computers & Internet
Disk boot failure insert system disk
First if your computer has a floppy drive, check to a floppy drive does not have a floppy disk in this drive.
Your computer cannot find the hard disk to boot up.
Go to your BIOS to see if the BIOS detects the hard disk, if not remove the hard disk and re-connect it again and see if it boots up.
If it still does not boot up then most likely the hard drive has failed.
To get the computer working again, install a new hard drive, install Windows and the computer's device drivers and your programs.
Dec 10, 2010 | Computers & Internet
I have a imminent failure and when I press F1 then I start installing Windows the system doesn't detect my HDD. I have a bad sectors and I know it. But I can't solve it. Can you tell me more information...
The motherboard is quering the 'S.M.A.R.T.' status of the disk-drive,
and the disk-drive is reporting that it is about to "fail".
So, your motherboard is showing that "Imminent failure -- press F1 to ignore this alert" message.
Take your computer to a qualified technician, to see if it is "too late" to recover any files from your disk-drive, and/or to install a new disk-drive, and to install Windows.
Nov 09, 2010 | Hitachi 60GB Travelstar 5K160 Ultra...
Microsoft Windows Vista Ultimate Edition Logo
254 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
