Question about Philips HTS-6500/37 System
Philips HTS6510 Sound Problem
On most DVDs the vocals on the soundtrack is quiet & sounds distant as though one of the channels is faulty. It seems like a faulty cable or is their a simple solution?
  • 1 more comment
  • Anonymous Jul 17, 2008
    I have the very same issue with th HTS6510 sound in general, it seems that a channel is missing and the sound won`t get any "full". Even with a music CD, the quality is pretty poor, like an old walkman when the headphones jack would not fit in correctly and we only had a part of the sound. Is it normal or is there any issue with the system?
    Any help is much appreciated!!
  • chcov Jul 17, 2008
    I'm having the same problem, did you manage to solve this?
  • Robert50 Oct 08, 2008
    Hi, that's a good comment regarding the phase cancellation - it's sounds feasible. However, the speaker cables have connectors that plug into the back of the DVD player, which would suggest that these have been manufactured incorrectly.
You seem to be having a "phase cancellation" problem
Are you sure the speakers are connected properly ? one of them might be connected in reverse - the + is in the - slot in one of the speakers which will cause phase cancellation problems, in other words, signals that are coming from both speakers will cancel out each other because one of the speakers is working in reverse phase.
Check wikipedia for phase cancellation.
Posted on Oct 08, 2008
Weak lead vocals
This is often caused when an earth wire touches a channel wire, check all your connections, especially those to the cartridge.
Jan 26, 2014 | Crosley CR249TA Turntable
I bought a Samsung AVR720 almost two years ago as well as a new Samsung blu-ray machine - to match our lovely Samsung series 6 TV (which our friend - who reviews all sorts of equipment - said was a really...
some of them require red , white, blue, green, an yellow audio jacks. make sure you have all the input plugs. or eles the tv will not use plugs it doesnt have.
Mar 05, 2017 | Samsung Televison & Video
No vocal or very distant vocal, just music on my itouch
Since you didn't list the brand name or model - I can only give some generic help.
The problem sounds like a "sound profile" mismatch on a system that has some sort of surround audio speaker set up. One example of a mismatch is (there are plenty of other, too): Your itouch has only a left and right (stereo) output and you might have the system trying provide some sort of dolby digital effect (theater, adventure movie, etc.) applied to it. Since it is lacking the expected input signal (center, rear left & right) - some audio info is lost.
Solution: Nothing is broken - you just need to cycle through the sound profiles on the system to locate the the one that restores the lost audio signals. Note which one is currently selected before starting - so you can return to it when done. You'll have to change the sound profile whenever selecting the itouch sound source.
If this is too generic - reply with your shelf system manufacturer's name and model number. Then we can dig deeper.
I hope this was helpful!
Jun 14, 2010 | Audio Players & Recorders
Hi my Philips HTS6510 Home Cinema is frozen, it just shows
Hi, mine is also blocked, completely frozen. it also shows AUX and won't react to anything. Have you already solved the problem? Whad dit you do?
thx for the effort to reply,
Dec 14, 2009 | Philips HTS6510/05 Theater System
Sound for DVDs
Turn Off or change surround sound mode in DVD system to get vocal sound (dialogues) in speakers.
Jun 03, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Audio function "Bypass" - problem
try to increse the volume centre channel level so that u could hear better vocals. or do one thing if u r connected with optical cable only. just connect single RCA cable from dvd players centre channel output to the TV input (Left/mono) so that u can only hear the center channel volume thru TV and all other from speakers even the LG is working..
Jan 24, 2009 | LG LHT734 System
Difrence between philips hts6500 and hts6510
The 6510 was marketed for countries other than the United States. The slash codes at the end of Philips products are country/region codes.
-Tha Mp3 Doctor
Jan 03, 2008 | Philips HTS-6500/37 System
Philips HTS6510- Content cannot be displayed (Non HDCP Compliant)
Hi Joey,
This is the my second HTS6510. I sent the first one back in August as it would not play the disc nor eject it and I'd only just got it. The replacement has worked well until recently when virtually the same problem you are experiencing happened to mine without "the contents cannot be displayed" bit. It corrected itself but did the same thing tonight and this time it sometimes displays the "content cannot be displayed" bit. I think it is the HDMI out connection that is at fault. Could be that it cannot cope with the sound, but I'm a long way from knowing how these things work. If you come back on site and know the answer please share it with me. I will be getting onto the seller in the morning as it's still under manufacturers warranty.
Oct 18, 2007 | Philips HTS-6500/37 System
Sound capabilities
The symptoms you describe are caused by a break in the earphone socket ground connection.
If you are confident enough, dismantle the player and re-solder the 4 connections to the earphone socket.
Oct 04, 2006 | Philips GoGear HDD6330 MP3 Player
Philips HTS-6500/37 System Logo
442 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
