Question about Amana Refrigerators
Snow or frost in the freezer, Amana model number ARB2107A; the freezer is on the bottom; ice cubes have NOT melted together and everything in the freezer seems to be frozen; the freezer setting is at 4, which is the setting that has previously been correct; the fridge is only 6 and 1/2 years old.
  • 525 Answers
Based on the information you provided you will have 2 scenarios here:
1. If frost is building up on packages or around the front then look for an air intrusion, i.e. something blocking the correct door closure (either door). Bottom basket not pushed in all the way, etc.
2. If frost is on the rear panel where the fan is located, then you would have a failure in the defrost system. Now, either you will find that #1 is the problem, which, at this point, that is what I believe, because of your food status, or you have been super observant and have caught a potential food loss issue in its early stage. Once a failure in the defrost system occurs, it will normally take 1-2 weeks before the unit can no longer absorb heat out of the box, due to excessive frost build up, and the unit will start warming up. Below is a link to a parts breakdown and diagnostics help if you determine that you have a defrost system failure.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 19, 2008
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Everything in the freezer has defrosted, temp setting at 6 (refrigerator compartment at 5). Amana bottom freezer model ARB210AB Water will not freeze, ice cream melted and frozen veggies and meat have...
Is there frost on the freezer panel? are the two motor and compressor running (freezer motor and condenser motor)? find this out 1st. this is nothing you did but if you are not mechanically incline at this point only a frig tech can properly check and tell you exactly what is it. theres are the things it might be...
compressor not working
condenser not running
freezer fan not running
thermostat not sensing temp.
stuck in defrost
heaters on too long
bi-metal shorted
timer not working
now if you paid alot for this frig at least get someone to look at it for a service call ($40-60) if it too high to repair then its time to get a new one
Mar 27, 2010 | Amana Easy Reach Bottom Freezer 20.5 cu....
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Clump of ice in bucket
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Jan 20, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Refrigerators Logo
228 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
