Question about Franklin Industries FCR360D Stainless Steel Refrigerator
Fridge will not run.
On have power to light,i think its the control board and i would like to replace the tranformer,have corrosion on it
  • 525 Answers
Below is a link to a source that can help you with parts and diagnostics.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 19, 2008
I have an LG fridge model GWL227hbya. the light build in the fridge had blown so i replaced the buld with original replacement part.
The bulb socket may have corrosion on contacts. Disconnect all power to unit and then clean out contacts to restore operation. Make sure that bulb is also fully inserted.
Aug 24, 2017 | LG Refrigerators
No power to pentair mastertemp 400. Power going into tranformer, and power to ignition control module. Replaced display motherboard. Still not lighting up. Replace tranformer?
Check the control fuse on the power interface board and also the fuse inside the silver box. The control loop will prevent the heater from coming on if it is open.
Jan 21, 2017 | Pentair Pool & Spa
Maytag frig model no mfi2569vem2 control panel not lit up and not coolong or freezing. light inside is on but dont here the motor running. we did have a power outage when issue occured
Sounds like the power outage took out your high voltage control board. This control board is located on the back of the fridge. Roll the fridge out of its position so you can get behind it. Once you have pulled out the fridge you will need to UNPLUG it. There will be a couple 1/4" screws securing the metal cover to the back left side of the fridge (if you are facing the back of it). Remove these screws to find another plastic cover which will need to be removed. This control board controls the fans and the compressor. You can take the control board out and look for a burn mark or a blown soldered fuse. According to your model number the control board part number is W10310240.
Nov 02, 2016 | Maytag Refrigerators
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
Re: Lights and fan problems for Sub Zero 532 Side by side refrigerator.
First of all if you're condensor motor is controlled by electronic control board varyable speed type you might want to think about looking at replacing the control board. But first I would take a voltmeter test to see if the fan motor is getting enough voltage. If the voltage varies with the temperature inside the box then you have a controller. If the voltage remaind constant (120) and the motor still slows down yoy have a bad fan motor. As far as you're like the problem goes the only thing I can think of besides loose wires or bad switch.would be if it operated off the same control board.
Dec 10, 2012 | Refrigerators
Fridge Won't Cool
First off that "condenser fan motor" needs to be replaced. It is not running near the speed it needs to. (I replace those all the time on the job) Here is the replacement to order.Also, based on the information you provided, it sounds like the main control board is sticking in defrost and you will need to replace the main control board on the unit. GE has an updated control board that address's this problem along with some other issues the original control board had.Here is the updated board to order.
All the parts come with a 365 day, any part, any reason return.
Keep me posted!
Nov 01, 2012 | Refrigerators
Hi ! my 3 years old fridge Samsung Rs2630ww
lashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.
Mar 24, 2011 | Samsung RS2630WW Side by Side Refrigerator
My tv turns on for about 2 seconds and then turns off. There is a high pitch sound even while it turns off
This problem causes and problems is the power supply board.Those tranformers on the power supply board one of those tranformer output coil not working anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com.Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 01, 2011 | Akai LCT3201AD 32 in. LCD Television
Frigidaire gallery fridge model glhs269zdw1 not working after power surge..fridge lights are on and I can hear fan running..the water dispenser also stopped working.
You are hearing the evaporator fan in the freezer but not the compressor motor, therefore no cooling. This is a classic symptom of a bad control board - you will need to check and replace the circuit board ! best of luck
Sep 27, 2009 | Electrolux Refrigerators
Fridge and freezer stopped working.Power still on (light on in fridge). Digital control for fridge and freezer shows straight line no numbers. Any suggestions?
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Jun 05, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Franklin Industries FCR360D Stainless Steel Refrigerator Logo
80 people viewed this question
Top Franklin Industries Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
