Question about Xante CL30 HSE Laser Printer
Paper Tray Oki /Xante ?
I need a 2nd Paper tray for my CL30. It is no longer sold by Xante. I got one from OKI. It fit, but the printer doesn´t ecept it.
Is there a way to make it work?
It sounds as if maybe the trays are not configured in your software. Access the printer driver and make sure that the additional trays are enabled. Under the Device Setting tabs, if on PC, available trays, ensure that you have the correct number of available trays selected.
??? If that doesn't work, you may want to check back with Xante to make absolutely sure they do not have the trays in question.
p/n 250-100075
Posted on Jul 07, 2008
Put A4 in upper tray error
Change the printer properties to use paper from the automatic feeder tray. And, unless you are in Europe, you probably don't want to specify A4 paper. Try "letter" or some other size.
The manual is at this URL. See page 49
Apr 25, 2016 | OKI Office Equipment & Supplies
How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Oct 07, 2009 | OKI B4600 Digital Mono Printer - Black
Printer no longer feeds paper from paper tray; I tried cleaning it, it sounds like the printer is trying to grab the paper but it does not grab it.
Remove the paper tray. Use a lint-free cloth dampened with rubbing alcohol (isopropyl) to wipe all around the black "rubberish" wheels right underneath the unit where paper tray goes. I learned that by calling Okidata.
Oct 05, 2009 | OKI C3400n Laser Printer
Oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Apr 14, 2009 | OKI C5250n Printer
380 Paper Jam
There could be a small bit of paper stock in sensor
near the bypass tray.
Jun 23, 2008 | Xante CL30 HSE Laser Printer
Oki printer problem
Possibly a defective paper sensor (small lever in the tray contacts
paper) Try removing, and inserting paper a few times if this clears it
then it was sticking.If that dosen't work then you will have to
disassemble it and inspect the area of the tray switch to determine
it it needs replacement
Nov 14, 2007 | OKI B4350 Laser Printer
OKI B4100 paper output. Frustrating!
If your oki is like the 4300 we use it may be as simple as making sure the extention for the back tray (where the paper is printing to now) is pushed all the way in. This actually selects the tray option. If this tray extention is pulled out at all, your printer will print to the back tray.
Oct 25, 2007 | OKI B4100 Laser Printer
Xante CL30 HSE Laser Printer Logo
110 people viewed this question
Top Xante Office Equipment & Supplies Experts
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
