Water doesn't stop filling tub in washer, water overflows everywhere. washer doesn't wash on super/large loads and doesn't spin on any loads. washer is only 2 years old
  • washerGE Sep 04, 2008
    GE model WPSR3100, water won't stop filling in any level, small, medium, large, or super load. Therefore, washer cannot start the washing cycle. Please provide detail solution if possible. Thank you.
  • Anonymous Mar 27, 2009
    my water will not shut off in the spin cycle, it has over flowed twice, I have to watch and listen for it everytime I wash clothes.
  • 3 Answers
Water not stopping filling is the pressure switch its a long thin tube that goes from the bottom of drum to the front top about the thickness of a pencil this needs taking off clearing through and checking for pin holes then refitting this should solve water problem
Posted on Jun 19, 2008
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Water does not shut off!!!
Check the timer in the back behind your knobs make sure it is working. That timer times how long for the water to run on all your settings and for everything else
Feb 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Leaks occur in spin/empty cycle
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
Nov 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Water fill control
it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. There is a mechanical adjustment for the level but it is a little fiddly to get the adjustment just right.
If it overfills from the drain hose:
then either the drain hose is too low and the water siphons out before it reaches the maximum or there is a tight seal at the drain hose to house drain port which will cause all the water to siphon out, this can also be caused by a drain hose being pushed too far down the house drain port.
Jul 28, 2008 | GE WDSR2080D Top Load Washer
Overflowing water
If the water comes out when filling, check your water valve by unplugging the washer when it is filling. If the water still runs, replace the valve. If the water stops, check the small tube that goes from the water pressure switch (in the consul) to the bottom of the tub. This must be connected without any holes or obstructions. If this is ok, replace the water pressure switch.
Jan 03, 2008 | GE WBSE3120B Top Load Washer
Open Questions:
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
