Question about Frigidaire ATF6000ES Front Load Washer
Washer problems my washer makes a loud noise in the spin cyclena vibrates
  • 413 Answers
Open the door, pull back the door seal then grab the plastic outer tub with one hand and the inner basket with the other hand. If you can lift on the basket and wiggle up and down, the tub bearing is bad.
Posted on Jun 19, 2008
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
Makes a loud noises when spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
MAKES A LOUD BANGING NOISE AT THE END OF SPIN CYCLES. WHEN IT IS SPINNING SLOWER, NO PROBLEM. IT IS NOT A PROBLEM OF BEING LEVEL.
heatman101
Apr 17, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing machine makes loud noise in spin cycle
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Dec 05, 2010 | Kenmore Washing Machines
My Kenmore Washer Elite HE3, front loaded, makes a very loud knocking noise when it spins ?
heatman101
Nov 09, 2010 | Washing Machines
Makes a loud sound when spinning
heatman101
Sep 08, 2010 | Maytag Neptune Washer
Washer makes loud noise during spin cycle
heatman101
Aug 31, 2010 | Kenmore 4292x Front Load Washer
Washer problems
Hi there!
The problem is probably the main drum bearing at the back.
Isolate power and water supplies.
The top will have to come off,(screws along top edge at back), then the motor mount slackened to remove the belt. Then try rotating the drum by hand, If the noise is still there, check for any items lodged between metal drum, and the outer plastic wash tub. If everything is clear, The noise will be from the rear bearing, which needs to be replaced.
I can assist you further with this.
Jun 19, 2008 | Zanussi ZWF1430W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
