Question about Intel Motherboard
Msi motherboard hi, i just assembled a pc intel core 2 duo 2.66 ghz e8300 msi p7n sli platinum xfx geforce 8800 gt (using one) 2x1 gb transcend 800 mhz 360 gb sata 19" samsung sync master. 500 w power supply well when i plugged in the power supply and pressed the power button, the fans and all strted to work but ther is no display on the monitor. there was no bios on the screen. no beep of the pc booting. the fans on the cpu and cabinet and graphic card were working. but no display. i checed the monitor with my laptop, it wrked fine. please help!! also is it mandatory that the smps will have a 8pin power supply..i seem to have only one 24 pin power. also i have a asus lite scribe fixed in. would the drive work only when O/S is installed..it didn work even when the fans were running.. m using a div-i dual to vga converter for the monitor. hey another thing. i have a wireless miscrosoft keyb and mouse. can it work even when no OS in installed??? else how do i input commands?
  • shaikh27 Jun 29, 2008
    hi.. as i switched on my pc i am not gettin sound and or i can play any music.and im gettin a message that install bus drivers before installing sound drivers.so kindly help me in solving this problem.
    my pc lg brand intel chipset msi 915g
    Sergeant:
  • 287 Answers
@ vinay2412 - YES you need a PSU wil either the 4 or 8 pin molex connector to power the motherboard correctly
the lightscribe drive will not read a DVD or CD until you boot the PC correctly
the wireless k/b will not work until you load the drivers etc. you need a PS2 or USB k/b to get thing going first until the OS is running and you can install drivers
@ shaikh27
your error suggest you need to load drivers from the motherboard driver CD. do you have this?
Posted on Jul 17, 2008
Hi. i have a compaq presario sr5025an. I have 2 gig of ram. I have the intel core 2 duo e4300 processor. I am after a grapics card. cheers.
To get the full specs of your mainboard go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00893006&lc=en&cc=au&lang=en&product=3401230&dlc=en#N198
This motherboard has 1 PCI Express x16 slot for a graphics card.
You could use:
Geforce 6 series (6800GT)
Geforce 7 series (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600 ,
GeForce 7300, GeForce 7200 and GeForce 7100)
Geforce 8 series (GeForce 8800 Ultra, GeForce 8800 GTX, GeForce 8800 GTS, GeForce 8800 GTS 512, GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT and GeForce 8500 GT)
Geforce 9 series (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO and GeForce 9400 GT
Geforce 200 series (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250 GeForce GTS 240 and GeForce GT 220
Geforce 400 series (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, Geforce GTX 450)
With your system however I would recommend nothing greater than a Geforce GTS 250.
Please rate me high.
Thanks.
Nov 01, 2010 | HP Computers & Internet
I have dell inspiron 1545 intel media graphics accelerator 4 series chip set family. i cant play good games like crysis, mass effect, assasins creed etc. what should i do to play it. anyone please help me?
Minimum System Requirements
OS – Windows XP or Windows Vista
Processor – 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista)
Memory – 1.0 GB RAM (XP) or 1.5 GB RAM (Vista)
Video Card –256 MB**
Hard Drive – 12GB
Sound Card – DirectX 9.0c compatible
* Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster.
** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
Recommended System Requirements
OS – Windows XP / Vista
Processor – Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory – 2.0 GB RAM
GPU – NVIDIA GeForce 8800 GTS/640 or similar
Apr 01, 2010 | Dell Inspiron 1545 Notebook
No post no beep
check your hard drive and make sure it's connected properly and set for master, not slave.
Feb 14, 2010 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Can we install dot net in p3 1.3 ghz system
yes sure u can install the .Net Framework on your pc. after installation it may support your windows a bit, and your pc will be faster then before it is...
good luck
shafky
Jun 19, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Bios don't boot on p7n platinum sli
check the voltage on the power connector going to the hard disk.
it should have 12volts in red and black wire and 5volts on the yellow and black wire.
the main problem the optical and hard disks can't be recognized is the low voltage supply the drives gets.
Apr 13, 2009 | Intel Motherboard
Need advise for upgrating graphics card
GET THE NVIDIA G FORCE 8400 GT IT IS THE NEWEST CARD AND IT WILL RUN EVERYTHING YOU HAVE.
Mar 27, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Is it compatible
Hi playboyalive, to answer your question! (Yes) the,
XFX nForce 790i Ultra SLI Motherboard will support Intel's core i7 extreme edition multi-core 3.2GHz CPU. The board can go higher. The highest tested by XFX is Intel's 3.73 GHz multi-core CPU. You can see all supported CPU's at the XFX link below;
http://www.nvidia.com/content/nforce700i/nForce_Intel_CPU_List.pdf
The above link was opened from this XFX link; http://www.nvidia.com/object/product_nforce_790i_ultra_sli_us.html
Thank you for using FixYa playboyalive!
Mike
Feb 04, 2009 | ASUS NVIDIA nForce Chipset A7N266-VM...
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
No display, no start up beep, no post and no boot
You need a Molex power plug (same as for your standard IDE hard drive or DVD drive to an 8pin adapter. A common product. If you can't get it locally.
Without this the board won't boot as there is insuffcient power on the motherboard to drive your display adapter.
Here is the link to the product at crazypc.com.
Also, if you have onboard video too, make sure the bios setup pages have the property set for primary display adapter to Add-in/PCIe.
Regards,
Worldvet
Jun 19, 2008 | Intel Motherboard
Intel Motherboard Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
