Got a 4 year old zanussi washing machine and its developed a fault where when it gets to the spin part of the program it just sits there and does nothing,read the manual about unbalanced loading but even with half loads it does it
  • 3 Answers
Check wether it does the same thing unloaded if not then its likely to be carbon brushes ,,, presuming it is tumbling durin the wash/ rinse cycles also check front filter zanussi wms will not spin if they cannot clear all water in the drum
Posted on Jun 19, 2008
MY zANUSSI zwh6140P IS LESS THAN A YEAR OLD AND IS JUST OVERFILLING WITH WATER AND WONT DO ANYTHING ELSE
It could be a blockage in a outlet pipe or in the filter or pump. The machine won't advance the program until it knows the water is gone.
Dec 23, 2012 | Zanussi Washing Machines
We have a Zanussi Essential 1400 6kg washing machine which is about two years old. It is not working , not turning. We live near Bridgend in South Wales, can you recommend a repairer for us in our vicinity...
Ideally if you are able to give us some input of the fault we can advice you other wise it is best to identify the nearest Zanussi service support close to your place.
Please check this out with a basic idea to identify the fault .If the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Sep 02, 2011 | Zanussi Washing Machines
My Zanussi nexus fl881 wont spin. Can you tell me how old this washing machine is and how to fix/whether to get new one?
6/8 years old.....Souynds like new motor brush kit needed. price of parts about £30. plus labour possible 30 mins work to fit..Hope this helps
Apr 01, 2011 | Zanussi F1045W Front Load Washer
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
My zanussi has a fault where it washes for about
THIS IS A TACHOGENRATOR FAULT ITS A SMALL MAGNET THAT SITS ON THE END OF THE MOTOR AND TELLS ELECTRONICS WHAT THE MOTOR IS DOING,THEY FALL OF A LOT ON ZANUSSIS TIP THE MACHINE BACK AND LOOK AT AT END OF MOTOR OPPOSITE TO PULLEY THERE IS USUALLY A SPRING CLIP HOLDING IT IN,THERE IS NO SIGNAL TO ELECTRONICS THATS WHY THE DRUM MOVEMENT IS ERRATIC.
Aug 12, 2009 | Washing Machines
Zanussi zwf1929w front loader
it could be either the heating element the machine is waiting to heat up before moving on or the brushes on the motor. somtimes the motor is able to spin without a load but struggles full up programmer faulty is a rare fault
Oct 30, 2008 | Zanussi FJS1225W Front Load Washer
My Zanussi F1245W Wont Drain or Spin
Check the drainpump. It could be burned og blocked.
Jan 20, 2008 | Zanussi F1245W Front Load Washer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
