Question about Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver
ACQUIRING SIGNAL I am having the same problem as many other subscribers with the words appearing and no sound, Isa there a forum to address the company about this problem that seems to be effecting a growing number of subscribers??
  • Anonymous Feb 03, 2009
    dasdasd
I had the problem of "acquiring signal" after years of working. The fix is simple. The connectors on the base unit that plug into the sportster, and the antenna connector on the rear of the base get slightly oxidized. Buy radio shack electronic contact cleaner (in a can) and spray a very small amount on the male connectors (both the antenna plug and the male to female connector that is in the dock itself. Plug the antenna in and out several times and swirl it. Place the unit into the dock and remove it several times. You will likely find the signal problem is solved. You usually dont need a new antenna, but simply a clean set of contacts. Sat signals are very very suseptible to the slightest impacts. Good luck!
Posted on Nov 19, 2009
I hope this helps somebody.My sportster was stuck on aq. signal every time I plugged it in.Then it would pick up signal and work for short time when the volume would cut out.I was tapping the top of unit till it completely stopped working.I took off the cover and unscrewed the six screws.I gently seperated the insides and blew out dirt and wiped off any contact surfaces.The plate behind the pins that looks like brass was dirty.Also the 4 square contacts on each side.I made sure the screws were tight cause squeezing unit would make it work.Put cover back on and it's like new.Turned it off and on 20 times and it vame on instantly every time!!! hope this helps- foz (thefoz@ptd.net)
Posted on Jan 28, 2009
Hey I have the same problem. I call Sirius up this morning and she suggested that my antenna is the issue.
AGHHH I am really upset as now I will have to wait to get this.
Posted on Jul 11, 2008
SOURCE:
I was driving along and I got a message "lost satellite reception.
Put it on the dashboard when it is acquiring signal, that helps it faster. If it locks up like that, disconnected the power for 20 seconds and then power it back on.
Oct 15, 2015 | Garmin nuvi 350 GPS Receiver
A coma computer enthusiast has installed an old ISA sound card in his PC. However, it locks up and doesn?t work when a tape backup unit is used on the system. What is the most likely cause of the problem...
ISA is a very old technology and cards usually require switches or links to be set to avoid conflicts with other cards. ISA is not plug-n-play like PCI or PCI-e.
The software talks to an ISA card by knowing parameters such as IRQ number, DMA number, address range. These values may be permanently set on some cards, while others allow changing via the DIL switches or jumper links. To get two ISA cards working in one PC, the two cards need to use their own IRQ, DMA & address ranges. Make sure there are no conflicts of settings on the sound card and the tape drive card.
Try changing the settings on one of the cards. The tape drive may be the easiest for this. The tape drive is probably connected via a ISA to SCSI interface card. This should have DIP switches or Links to allow the above settings to be changed.
Oct 08, 2011 | Creative Labs Sound Blaster Live! 5.1...
Acquiring network address
Sometimes you have to change your computer's settings or the routers settings to know what type of encryption its looking for otherwise it will just stay on acquiring.
Sep 19, 2009 | Linksys WRH54G Wireless Router
Acquiring Signal
Try resetting it to defaults if you haven't done that yet. I had a similar problem with a Stratus 4, and that took care of it for me.. Sounds like perhaps some kind of NVRAM gets corrupted and a full reset clears it up.
Good Luck. Hope it helps you like it did me.. Just remember to jot down all your presets first, because you will need to reset them.
Jun 03, 2009 | Sirius Satellite Radio Receiver
Cannot locate saltellite or Acquiring satellite
The error means it can't pick up valid GPS signals. In other words, bad reception.
Has the unit ever worked? Does the unit have an internal or external antenna? Are the batteries fully charged?
Try the unit outside with clear view of sky instead of in the car. This will give it the best chance of picking up a GPS signal.
If it still doesn't then suggest something broken inside.
May 20, 2009 | Garmin nuvi 200W GPS Receiver
"acquiring network address" problem
The password might have been changed that's why you keep getting "acquiring network address", the password is incorrect. What you can do is just reset the router. There's a reset button at the back of it, press and hold it down for 10 seconds then release, unplug the power now for 10 seconds then plug it back in. That will disable the wireless password, just re-enable it.
Oct 26, 2008 | NetGear WGR614 Wireless Router
Laptop won't recognize the network, No installation CD, other solutions?
This sounds like you have either WEP or WPA enable on the network you are trying to connect too. Are you connecting through a wireless network? If not try adding a passphrase using WPA-TKIP and see if that helps.
May 06, 2008 | NetGear WGR614 Wireless Router
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver Logo
2,749 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
