Question about Panasonic KX-P6500 Laser Printer
Print is obliterated with 4 broad hoziontal strips on paper
The printer won't produce a clean print. The green roller on the proces unit is lined with toner and cleaning with cotton wool does'nt seem to help. The roller just picks up fresh toner hence the print output appears with broad horixontal strip on the page .
  • 300 Answers
The green roller is the OPC drum, and as with many panasonic laser printers the cleaning mechanism doesn't work properly. The only way to solve this is to replace the unit.
Posted on Jun 19, 2008
Scuff/score lines down print plus central grip mark
Possibile solutions
1) Complete cleaning using copressed air or lint free cloth
2) check the cleaning blade on your drum (Round Glass cylinder)3) Change your drum unit
4) replace rollers
Oct 10, 2013 | Canon Pixma Ix6550 A3 Inkjet Printer
My epson stylus tx110 is noisy and does not print right. i think the rollers are busted.. some words are split in half..
Eventually all inkjet printers have this problem. When the printer is doing its thing (printing) there is a small amount of vaporised ink floating around the inside of the unit. This vapor collects on everything inside of the printing chamber, including the sensor strip the printer uses for tracking the print heads location. Luckily it's an easy fix, just clean the sensor strip.
To do this, get yourself some rubber gloves (unless you don't mind having Technicolor hands that is) and some lint free paper towels. Put the gloves on, then wet half a sheet of paper towel so its wet, but NOT dripping wet. open the printer and allow the ink heads to travel to middle. When they reach the middle, unplug the machine so the head stays unlocked and out of home position (where the print head goes when not printing). With the printer unplugged and the print head unlocked, locate the thin semi transparent strip running from one side of the printer to the other, it sorta floats there in mid air as its supported on either side by small metal tabs. Starting at the print head home position , gently, clean this strip with the wet paper towel, making sure not to apply too much pressure as you can pull the strip off the hanger tabs or erase the small lines printed onto on the strip. Once the home position section of the strip is cleaned, dry it off and slide the print head into it's home position and clean and dry the rest of the strip. When done, plug in and power up the unit, then do a test print to ensure the problem is fixed.
Hope this helps.
May 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the...
this rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Lexmark X2350 won't pull paper to print.
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Press the "Power" button to turn the printer power off.
2. Press and hold the "Copy" button.
3. Press the "Power" button one time and release it(keep holding the copy button).
4. Let go of the "Copy" button after the power LED flashes once.
5. The self-test will produce 1 page. The test is not continuous.
The self-test should print out a set of black and color bars.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 11, 2009 | Lexmark X2350 All-In-One InkJet Printer
Noise then paper jam then printer head stops abruptly and does not work at all
Clear the paper jam. Then with a cotton pad and some alcohol, clean all the rollers that you see. If you can get to the rear of the printer, make sure that there isn't any paper residue back there, and also clean the rollers in the back. There is a platen (rod that the print head slides on) clean that too.
Then carefully clean the strip in front of the print head.
Also, never move the print head while the power is on, it will cause the unit to get off it's alignment.
Let me know what results.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | HP DeskJet 940c InkJet Printer
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  1. Turn off the all-in-one and unplug the power cord.
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
Black line down the page
Is the line on the front of the page or on the back? If on the back, you need to clean the platten which is the piece of plastic under the paper.
If its on the front, and you say "It lools like a rubber cover may be missing off of one of the rollers", could you upload a picture of this roller? I don't recall any covers on rollers in Canon printers.
Try this, print out a blank page. If line is still there, print out 10 blank pages. If line is still there and has not faded, this is unusual and may need servicing. There may be a problem with the encoder strip (it's a clear plastic strip with black lines running the length of the printer slightly behind the head), Try cleaning it on both sides with a little windex on a q-tip. It's delicate so be careful.
If the line looks faded after printing 10 blank pages, some ink has dripped onto something that is contacting the paper. This could be a roller, the bottom of the head carriage or even a hair or piece if dust that is stuck in the machine or on the bottom of the head. In this case, I would recommend cleaning everything. Revove the head (tell the machine you're going to replace ink, and when it moves the head into the centre position unplug the power cord.
Remove the head and clean off any dust or hairs on the bottom. Run a Q-Tip along the bottom of the carriage assembly wherever you can. Clean any accessable rollers. If you can get at it, clean the wiper on the purge unit (the unit the head sits over when it is parked), as well as the seals.
Reinstall the head and ink, close the lid, power up and retry printing.
I hope this helps. If not, there could actually be a fault with the printhead or one of the circuit boards
Dec 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Panasonic KX-P6500 Laser Printer Logo
109 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
