My s key appears to be stuck on. I have cleaned it by taking the key off. Everything appears normal except I can not type the s key once I have pressed escape and/or the backspace to remove it from where ever the cursor is as it continually repeats 's'. If I go into control panel or any file anything that starts with 's' will highlight in turn continually just like the 's' repeating.
  • Anonymous Dec 07, 2008
    Same problem with my laptop. When windows starts up, it beeps continuously until I press Escape or backspace,. If I open notepad on a fresh restart, it keeps typing in 'S'. Once I press escape or backspace, it will not allow me to press 'S' anymore.
    Novelist:
    Scholar:
  • 70 Answers
The keyboard is broken. Usually this happens when something is spilled on the inside switch parts. A new keyboard is about $20.
Posted on Jun 19, 2008
Tip
Delete An undeletable File
Open a Command Prompt window and leave it open.
Close all open programs.
Click Start, Run and enter TASKMGR.EXE
Go to the Processes tab and End Process on Explorer.exe.
Leave Task Manager open.
Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.
At the command prompt type DEL <filename> where <filename> is the file you wish to delete.
Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.
Close Task Manager.
Or you can try this
Open Notepad.exe
Click File>Save As..>
locate the folder where ur undeletable file is
Choose 'All files' from the file type box
click once on the file u wanna delete so its name appears in the 'filename' box
put a " at the start and end of the filename
(the filename should have the extension of the undeletable file so it will overwrite it)
click save,
It should ask u to overwrite the existing file, choose yes and u can delete it as normal
Here's a manual way of doing it. I'll take this off once you put into your first post zain.
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:*** (The stars stand for your folder)
5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:progra~1kazaal~1
6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.
7. Now to delete the file type in del ***.bmp, txt, jpg, avi, etc... And if the file name has spaces you would use the special 1st 6 letters followed by a ~ and a 1 rule. Example: if your file name was bad file.bmp you would type once in the specific folder thorugh command, del badfil~1.bmp and your file should be gone. Make sure to type in the correct extension.
on Oct 09, 2010 | Computers & Internet
Tip
Delete an undeletable File
Open a command Prompt window and leave it open.
close all open programs.
click Start, Run and enter TASKMGR. EXE
Go to the Processes tab and End Process on Explorer. exe.
Go back to the command Prompt window and change to the
directory the AVI ( or other undeletable file) is located
in.
Go back to Task Manager. click File, New Task and enter
close Task Manager.
or you can try this
Open NOtepad.exe
click File>Save as..>
choose "All files" from the file type box
in the "filename" box
pur a " at the start and end of the filename
click save,
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:\*** (The stars stand for your folder)
5. If you cannot access the folder because it has to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces.
Example: cd c:\progra~1\kazaal~1
7. Now to delete the file type in del ***.bmp, txt,jpg,avi,etc... And if the file name has spaces ypu would use the specific folder throgh command, del badfil~1.bmp and your file should be gone. Make sure the type in the correct extension.
on Jan 31, 2010 | Computers & Internet
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Ninemsn page corrupt on firefox
Go into firefox Tools and select "Clear recent history" and select everything to clear out. That will clear out all the saved pages and should clear up the problem.
May 22, 2012 | Computers & Internet
Pc in safety mode
g'day!
to get to your PC's safe mode:
  1. restart the computer.
  2. as the computer restarts, begin pressing the F8 key after the Gateway BIOS logo appears until the Windows Advanced Options Menu screen appears.
  3. on the Windows Advanced Options Menu screen, use the arrow keys to select Safe Mode, and then press the ENTER key.
  4. You are now in the Safe Mode of your PC. take note: that the display may appear to be larger than what you normally see. this will return to normal once you reboot it.
cheers mate!
jelo a.
Aug 17, 2011 | Gateway 505GR PC Desktop
How to reinstall windows xp if files are missing??
actually you can reinstall your xp system but this you can't, why:
the reason
your windows xp system are being updated every month...
the version from original system are being extracted to a new version....
by this time reformat you hard disk...
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
I have a virus in my C:\Document and Settings called tazebama.dll, hook and another tazebama.dl_ which i cant seem to remove them. the task manager, regedit, msconfig, are all disabled and any application...
Good morning! please try to download CCleaner thru CCleaner.com website and try if the problem issue can be fix. Otherwise, we have to reinstall the Windows Operating System again. best regards.
May 05, 2009 | Computers & Internet
Why my pc always typing automaticly?
You could very well have a stuck key on your keyboard. I've seen this problem many times. Shutdown your computer, remove the keyboard and clean it very well. Check for any keys that appear to be stuck. If all looks OK, plug keyboard in and power up computer. If that doesn't work, you may have a bad keyboard.
Apr 21, 2009 | Computers & Internet
Typing delay
I would suspect that you maybe have spyware and malware issue's. you need to get that process list down to an average of 35-40.
spybot is an excellent application to help in a situation like this. Search for it on google.
Apr 16, 2009 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
